HP Envy 15-W x360 448.04805.0021 Intermittent Boot
  • mullspeed
    • May 2021
    • 24
    I've got this board to repair, it is intermittent to boot. If you leave it without power for about a week then it will boot first time but not again unless you leave it. It really needs a few days, overnight is not enough for it to reset!!!
    I've reflashed the bios with the latest .bin by removing the IC, but get the same result as with the original BIOS.
    I noted that when I attach power for the first time after leaving the board unpowered I get 7 white flashes on the charge LED (no battery attached, literally the motherboard with some RAM on the bench, connected to an external monitor) and the board will boot. The next time I apply power the I get a rapid orange LED but no booting and then after that I get a solid orange LED but no booting.
    I have confirmed that the power button is switching from 3V3 to 0V and the charger output (no battery) is 12.5V.
    Could it be the KBC IC? I've no idea where to start on this?!
  • mon2
    • Dec 2019
    • 13835
    Re: HP Envy 15-W x360 448.04805.0021 Intermittent Boot
    Link or post the schematic and/or board markings.
    If not available -> locate the power in DC connector -> review the mosfets that should be nearby (likely 2 of them) -> and the charger IC should be close to the mosfets.
    The surface mount markings of the charger IC are important - probably 'BQ' (now a TI company; formerly BenchmarQ).
    • mullspeed
      • May 2021
      • 24
      Board is Laduree1.0 MB 14257-2 448.04802.0021
      • mullspeed
        • May 2021
        • 24
        Charger IC is BQ24737
        • mullspeed
          • May 2021
          • 24
          SCH attached
          • mon2
            • Dec 2019
            • 13835
            Ok. Review this thread which is similar:
            https://www.badcaps.net/forum/showthread.php?t=62235
            From the datasheet that is available from TI, we can approximate what is going on with your logic board. TI does private label parts for OEM accounts so some are in the witness protection program.
            With great care, measure the voltage on the mosfet pins that are close to your DCIN power connector. As per sticky above from @Piernov, you should find 2 x DCin mosfets.
            We are interested to know the voltages on each pin of each mosfet.
            Pins 1-2-3 = SOURCE pins ; pick one
            Pin 4 = GATE
            Pins 5-6-7-8 = GATE pins ; pick one
            Often first or second or maybe both mosfets get damaged and need to be replaced.
            They are very inexpensive (~1 USD) but will require tools and patience to replace.
            You may have some bad caps on the board but TBD. Bad caps draw too much current and the current sense circuit will shut down the power supply leg.
            • mullspeed
              • May 2021
              • 24
              Both Fets have 19.7V on drain and source and 6.5V on the gate, which is what is expected as per the circuit on P44 (the gate voltage I mean)
              • mullspeed
                • May 2021
                • 24
                I also have a board for spares, so I've swapped the BQ chips over but there is no difference to the voltages on the board or operation of the board.
                • mon2
                  • Dec 2019
                  • 13835
                  These charger ICs use N-channel mosfets. Being N-channel, the gate needs to be ~6 volts higher than the voltage on the source.
                  So the mosfet requires ~25 volts to ENABLE for this case (19v + 6v).
                  If you do not have 25 volts (approx) then the charge pump inside the charger is not working or is not enabled.
                  To investigate further, need to know the voltage on each pin of the charger IC. These measurements will help to diagnose if the charger IC is working properly or not.
                  • mullspeed
                    • May 2021
                    • 24
                    The FETs in the schematic are P channel.
                    I'll get some more measurements tomorrow, thanks for your help so far.
                    • mon2
                      • Dec 2019
                      • 13835
                      A bit unique setup for the 2 x DCin mosfets.
                      The first one is indeed P-channel. So this means the gate voltage should be NEGATIVE (lower voltage) than the source to enable. This enable function is performed by the mosfet 2N7002 @ PQ4401. When PQ4401 is enabled with a positive voltage at the gate of this mosfet, then the gate of PU4401 is pulled to a lower potential due to the resistor @ PR4406 building up a voltage divider since it is now connected to ground -> voltage @ pin 4 junction will become lower than the DCin voltage of 19v forcing the mosfet PU4401 to enable.
                      The 2nd one is N-channel and driven directly by the charger IC. The boosted voltage on the gate pin #4 is still required.
                      Datasheets for both mosfets are attached.
                      Tomorrow, also remove all power -> measure the resistance across the mosfet pins so we can check if they are defective or not.
                      source & drain
                      source & gate
                      gate & drain
                        HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                        This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-06-2024, 12:18 PM
                        HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-06-2024, 11:17 AM
                        HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                        This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 06:51 AM
                        HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-06-2024, 06:50 AM
