Re: Acer Spin 5 - Turns on and off after a few seconds
A lot of weird power issues on Acers are usually keyboard related, as power button is integrated. Original fault fits what I’ve seen. Disconnect keyboard and power on by shorting the 2 end pins of the connector with tweezers (usually pin 27/28) to rule it out.
Replace the noted mosfet and test again.Leave a comment:
Something odd happens when the battery is connected now. The system turns on with high fan spin, but no display still. The battery is also not charging. PU4402 drain starts at 12V and drops to 0.83.
Another thing I noticed while poking the probes around and trying to analyse measurements (voltages), is that there is voltage anywhere I could check other than at PG4707 & PL4801.
PR4802 is 2.49V (I thought this should be 5V?).Last edited by DanFen; 07-11-2022, 05:20 AM.Leave a comment:
Unfortunately I can't find any P-Channel mosfet with that package on any of the boards I have. So that means I'd need to order a replacement.Leave a comment:
In this case I'll try to find something similar on some other boards I have around.Leave a comment:
PU4401
between source (1-2-3) & drain (5-6-7-8): 9.64 (in 20K mode)
When using the replacement - check the same pins to compare while it is out of the circuit. The same testing should show the 'fresh' mosfet to be a much higher resistance reading than this (defective) one.
Is it normal it keeps on rising? Is the meter charging it the moment I start measuring?
https://www.engineersgarage.com/test...et-part-16-17/Leave a comment:
PU4401
source (1-2-3) & gate (4): 100 (in 200K mode)
gate (4) & drain (5-6-7-8): ~.975 ( in 2M mode)
PU4402
between source (1-2-3) & drain (5-6-7-8): starts at 75 (in 200K mode) and rises very quickly until out of range
source (1-2-3) & gate (4): starts at 175 (in 200K mode) and rises very quickly until out of range
gate (4) & drain (5-6-7-8): starts at 75 (in 200K mode) and rises very quickly until out of range
Hope I did it correctly. Is it normal it keeps on rising? Is the meter charging it the moment I start measuring?
Remove all power. Meter in resistance mode (start with the lowest scale).
Check the resistance across the mosfet pins @ PU4401.
This is a 8 pin device (4 on each side).
Check the following for resistance:
Post each measurement and the scale on the multimeter used for the test.
Repeat the same tests on the battery mosfet @ PU4402.
If you see '1' or 'OL', then switch to the next higher resistance scale on your meter.
We are checking for a low resistance on the mosfet = defective.
see here for reference (review the resistance chart):
http://electronicsbeliever.com/how-t...0good%20MOSFET.Leave a comment:
Checked EC8910 for 19V_DCBATOUT and it's 19.49V
REGN on the charger IC is 6V.
This is after it shut down.
Focus on sheet 44 of the schematic = TI Charger IC (PU4403).
3) Check the voltage @ 19V_DCBATOUT - what is the voltage ?
4) After the logic board shuts down, review this 19V_DCBATOUT voltage again. Measurement ?
5) What is the voltage on pin # 24 (PWR_CHG_REGN) of PU4403 charger IC ?Last edited by DanFen; 07-10-2022, 03:40 PM.Leave a comment:
Post the voltage readings requested in #2 above.Leave a comment:
Yes, the same as that person'sAnd now I have the BV :P (of course)
Review this thread for possible schematic & BV files for your logic board.
Does your logic board look the same as what was just posted ?
https://www.badcaps.net/forum/showth...86#post1147886
LOL - you posted at the same time - is your board the same ?Leave a comment:
Referred to datasheet of that IC, and REGN is 6V.
EDIT: Downloaded a similar schematic from this thread: https://www.badcaps.net/forum/showthread.php?p=1083332Last edited by DanFen; 07-10-2022, 03:16 PM.Leave a comment:
I checked them in beep mode, and disregarded the reading. Maybe that's why I thought they're short. Resistance is 3.2 on lowest scale.
At this stage everything is disconnected from the mainboard, including battery, RAM, m.2 SSD, and the rest.
For some odd reason at one point it stayed on but nothing on screen, now it's doing the same thing but no display.
Unfortunately I don't have the schematics for this board.
No. Most likely the caps are fine as the measurements may be misunderstood. You are checking the resistance to ground values ?
What is the scale used on your multimeter ? Use the lowest scale.
What are the resistance readings in ohms ?
CPU rails = low voltage rails and low voltage rails are often low in resistance, by design.
Having the logo up is a good sign.
A few suggestions:
1) Remove the battery and drives, etc. to remove them from the equation.
2) Boot up normally -> confirm you see the logo on the display screen.
5) What is the voltage on pin # 24 (PWR_CHG_REGN) of PU4403 charger IC ?Leave a comment:
the caps behind the CPU all seem shorted out. If this is the case, would it still display the logo?
A few suggestions:
I have an Acer Aspire Spin 5 that turns on, displays the Acer logo, and turns back off. This happens in approximately 5 seconds. It won't turn on by itself after that, it stays off.
The mainboard is Drift_SKL 16801-1M.
I've already tried disconnecting everything, including the battery. I've also removed the CMOS battery for a while, and still no luck.
The only thing I could find is that the caps behind the CPU all seem shorted out. If this is the case, would it still display the logo?
Other than this, I also noticed that the voltage around the CPU (after it power off) keeps fluctuating between ~0.3V - ~0.9V. Measured at one of the coils. Other than this I don't know what else I can check.
Thank you in advance for any help.Last edited by DanFen; 07-10-2022, 02:09 PM.Tags: None
This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...09-07-2024, 03:10 AM
This specification for the Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Enterprise Spin 513 R841T boardview and Acer Chromebook Enterprise Spin 513 R841T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-07-2024, 01:30 AM
This specification for the Acer Chromebook Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display, Google Chrome OS, Silver) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display, Google Chrome OS, Silver) boardview and Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen...09-07-2024, 01:00 AM
This specification for the Acer Chromebook Acer Chromebook Spin 311 CP311-3H - (MediaTek 8183, 4GB, 64GB eMMC, 11.6 inch HD Touchscreen Display, Google Chrome OS, Silver) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 311 CP311-3H - (MediaTek 8183, 4GB, 64GB eMMC, 11.6 inch HD Touchscreen Display, Google Chrome OS, Silver) boardview and Acer Chromebook Spin 311 CP311-3H - (MediaTek 8183, 4GB, 64GB eMMC, 11.6 inch HD Touchscreen Display, Google Chrome OS,...09-06-2024, 10:20 PM
This specification for the Acer Chromebook Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display, Google Chrome OS, Blue) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display, Google Chrome OS, Blue) boardview and Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display,...09-06-2024, 09:30 PM
- Loading...
