ASUS ROG Strix G15 G512LW-HW038 not powering up
  • Rotter
    • Mar 2007
    • 22
    i would appreciate any help with this Board very much.
    Model: ASUS ROG Strix G15 G512LW-HW038
    MB: G532LWS R1.3
    History:
    slight waterdamage around U3505 (IT8299E) and PQ8817,
    someone else had a go at cleaning the board and resoldering U3505.
    i replaced 2 resistors (R5707 and R3021) and a few bad looking capacitors in that area.
    Behaviour:
    Upon pressing the Power Switch, all voltage rails but +VCCGT come on for about 1 second with a current consumtion of about 1.84A, then the current drops to about 30mA varying for about another 4 seconds, then drops back to <1mA.
    32KHZ clock RTC_X1 and RTC_X2 are present,
    24 Mhz is also present at XTAL24_OUT and XTAL24_IN
    looking at all kinds of singnals during power on i noticed the following:
    1. DDR4_DRAMRST# is at 0.11V, (see scope pictures), Resistance to Ground with no power: 650 Ohms. (this should be ok i guess since it has a 470Ohms pullup to 1.2V which itself has about 200Ohms to Ground)
    2. VSUS_ON has some kind of Prepulse which of course produces the same kind of pulse in the dependent voltage rails like +3VA_DSW (again, see scope pictures) Maybe this is completely normal, i do not know.
    3. No Communication at SMB_DAT_S, (see pictures) should there be communication already without DDRRESET# being High?
    4. No RAM Clock (M_B_CLK_DDR0/1)
    Other than that i could not find anything amiss.
    Battery is charging properly, Fans do not start at all.
    What i did so far:
    - inspected the board under the microscope for additional waterdamage / missing or corroded parts
    - Tried different RAM modules (known good ones), without any change.
    - reflashed the bios chip with one from the internet (cleared the ME region first) -> also no change.
    I will attach the bios files i used and the Schematic + Board View.
    The Oscilloscope pictures always have ALL_SYSTEM_PWRGD as CH1 for reference. The Signal Name shown is included in the name of the Pictures.
    i see this primarily as a learning experience and am happy for every piece of Info which could help to bring this board back to life.
    Link to schematics & boardviews https://www.badcaps.net/forum/troubl...atic-boardview
    Best Regards
  • Rotter
    • Mar 2007
    • 22
    Re: ASUS ROG Strix G15 G512LW-HW038 not powering up
    i tried now for quite some time to read the EC Rom with no success.
    The Tool i use is SVOD V1,
    is anyone here aware if SVOD V1 is capable of reading this EC (IT5125VG-128)?
    The Schematic mentions IT8995VG as the EC in some places, are these compatible?
    Best Regards
    • arthur_las
      • May 2022
      • 6
      • United Kingdom
      I ve got asus G17 with the same board, fans spin for one second , keybord flashes , I can see on thermal camera that GPu and CPU get hot , then everything dies after 5 seconds , no voltages , any suggestions,
      thanks for the schematics..
      • arthur_las
        • May 2022
        • 6
        • United Kingdom
        can you telll me what kind of resistances you got cpu coils , mine seem low 1.7 ohm...
        • mon2
          • Dec 2019
          • 14360
          Start with the usual dcin mosfets.
          Power adapter the original and suitable for this board?
          Measure the voltages on the source, gate, drain of the 2 x dcin mosfets (PQ8901 & PQ8902).
          • arthur_las
            • May 2022
            • 6
            • United Kingdom
            thanks for reply
            I've got same readings on both mosfets:
            drains, sources 19.5VDC
            gates got 25.4 VDC
            • mon2
              • Dec 2019
              • 14360
              The voltages appear to be ok and the high gate voltage means the charger IC wants the mosfets to pass the voltage to the logic board.
              Let us confirm the mosfets are not shorted.
              Remove all power -> meter in resistance mode.
              Then check the resistance across each of the same DCIN mosfets as follows:
              source (1-2-3) & drain (5-6-7-8)
              source (1-2-3) & gate (4)
              gate (4) & drain (5-6-7-8)
              Post each resistance value and also the scale used on your meter.
              If you see '1' or 'OL' on the meter -> switch to a higher resistance scale till you have a proper measurement. A low resistance = defective mosfet.
              • arthur_las
                • May 2022
                • 6
                • United Kingdom
                the charger is 180W it is written that is compatible with ASUS laptops but it is not genuine one
                sometimes laptop tries to start sometimes not when it does I'm going to try to measure all the voltages now I've got nothing...
                • arthur_las
                  • May 2022
                  • 6
                  • United Kingdom
                  I've checked it already in diode mode for a short , resistances are within 2.5- 6 Mohm, between gate source and drain on both mosfets all various possibilities...
                  I couldn't find any hot spot, any shorts on the board, only GPU and CPU do get warm evenly to 50-60 degrees then everything stops...
                  thanks
                  • mon2
                    • Dec 2019
                    • 14360
                    The low CPU coil resistance @ 1R7 is of concern but wait on other comments.
                    Have you reflashed the BIOS ? Archive the original contents and attempt to reflash the bios to see if that helps.
                    • arthur_las
                      • May 2022
                      • 6
                      • United Kingdom
                      so finally some shorts appeared on 1V rail and 1.8 V rail, maybe i was trying too many times to power up... checking now relevant ics
                      • mon2
                        • Dec 2019
                        • 14360
                        Post your resistance readings but as always, no power when checking resistance.
                        The low voltage rails may be ok with a low resistance but post the readings.
                        • elvid018
                          • Aug 2022
                          • 3
                          • dominican republic
                          Best Regards
                          I'm actually looking for a programmer that might support the IT5125, the one I have gotten closer is the ELNEC series as it shown in this list.
                          https://www.elnec.com/sw/dev_html/it...._inc._dev.htm
                          Now that you mention the EC IT8995, I just checked some random pins and yes the pines declares as EC IT8995, has the exact same connection as the IT5125 shows on the schematic.
                          • elvid018
                            • Aug 2022
                            • 3
                            Please let me know, if you where able to read and write the EC bios with SVOD, since I'm looking forward to buy a programmer that gets the job done.
                            • elvid018
                              • Aug 2022
                              • 3
                              Actually those readings do not necessarily means that you have a short, it is normal to measure really low impedance on CPU and GPU power rails. If you still need help let me know...
                                ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                09-07-2024, 01:00 AM
                                ASUS ROG STRIX-G16-G614JV-N4008W Notebook Strix G16 Specification for Upgrade or Repair
                                This specification for the ASUS ROG STRIX-G16-G614JV-N4008W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the STRIX-G16-G614JV-N4008W boardview and STRIX-G16-G614JV-N4008W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 06:40 AM
                                ASUS ROG STRIX-G17-G713PI-LL044W Notebook Strix G17 Specification for Upgrade or Repair
                                This specification for the ASUS ROG STRIX-G17-G713PI-LL044W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the STRIX-G17-G713PI-LL044W boardview and STRIX-G17-G713PI-LL044W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 06:38 AM
                                ASUS ROG Strix Notebook Strix SCAR 15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG Strix Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Strix boardview and Strix schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ROG Strix Notebook...
                                09-07-2024, 06:21 AM
                                ASUS ROG ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB Notebook Strix Specification for Upgrade or Repair
                                This specification for the ASUS ROG ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB boardview and ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                09-06-2024, 11:20 PM
