Dell Inspiron 15 7567
  • Gaboorigin
    • Mar 2022
    • 6
    • Mexico
    I have a dell laptop and it was working well and suddenly it turned off and when i tried to turned on it appears a blue screen saying ACPI Bios error i searched and disassembly the laptop and i found that the PL900 conductor was burned so i need to change it but i dont know with which one should i change it here is the picture of how it is (The laptop is with a technician friend mine) but i dont know the Voltage amp and ohm and size should i look for. Please help me i have some motherboards to look around if you need pics of the coductors, resistors and stuffs
    Last edited by piernov; 04-03-2022, 03:26 AM. Reason: remove broken external image
  • mon2
    • Dec 2019
    • 14219
    Re: Dell Inspiron 15 7567
    No picture was posted.
    List or take pix of any markings on the logic board so it can be identified.
    • JaroTech
      • Mar 2015
      • 351
      Hi, the PL900 in the schematic is a high current ferrite chip bead, its number is HCB2012KF-121T50. I hope this will help you.
      • reformatt
        • Feb 2020
        • 1412
        Value of the choke isn't all that important, it's primarily a filter to suppress noise from the GPU back onto the main rail. You could just steal a choke off another board really. It's a common enough failure on this model due to a shorted bypass capacitor after the coil. Replace the defective cap and put on a new coil and you are good to go.
        • Gaboorigin
          • Mar 2022
          • 6
          • Mexico
          This is helping a lot so i could find something similar in some motherboard i have around AWESOME
          • Gaboorigin
            • Mar 2022
            • 6
            • Mexico
            So any inductor would make it work? Or i need to look something specific cus i didnt find any other PL900 on the boards i was looking
            • reformatt
              • Feb 2020
              • 1412
              Ferrite beads differ from regular coil inductors, so they are spec'd differently. Rather than inductance, they spec them as impedance (in this case 120 ohms) when the bead is saturated. DC current still has minimal impedance, but any noise has a resistance of 120 ohms. Any switching noise from the 1.35V buck converter is thus prevented from spilling out onto the 19V main rail.
              So you are looking for a ferrite bead used in a similar position (i.e. feeding a buck converter) on another donor board. 120 ohm rating and 0805 size is nominal, but something close to it will do.
              • piernov
                • Jan 2016
                • 4435
                • France
                Current rating for the ferrite bead is the most important specification if you don't want it to burn again.
                Also the impedance is specified at a certain frequency, in most cases 100 MHz.
                • Gaboorigin
                  • Mar 2022
                  • 6
                  • Mexico
                  I think i attached the image correctly
                  • mon2
                    • Dec 2019
                    • 14219
                    Yes, the pic and above details are good.
                    Part is a ferrite bead
                    120 ohms, 2012 size, 5A rating.
                    From where do you source your parts?
                    This should be available from Mouser, Digikey, Arrow and other electronic shops.
                    • Gaboorigin
                      • Mar 2022
                      • 6
                      • Mexico
                      A local electronic store sells the part but they say are "Generic" they dont have the model but it is 120ohm, 2012, 5A should i buy these? i speak spanish so they told me "carbon resistor" so idk if should i buy it
                      • 66nakyoz
                        • Dec 2021
                        • Turkey
                        Hi All,
                        after reading all your posts I ordered the bead from china and changed it.
                        After disassembling the board there was neither a burn nor something anormal to see.
                        Changed the ferrit bead but no change.
                        Still the windows installation stops at the same point when seeing the first logo.
                        Has anyone another suggestion how to solve this damned problem?
                        Thx in advance.
                        • sk1087
                          • Oct 2023
                          • Deutschland
                          Hello all together,
                          did you order the component "HCB2012KF-121T50_0805" and happen to have any left? I'm interested in buying some from you.
                          Thanks for your reply
                            DELL Inspiron 7567 Notebook 7000 Specification for Upgrade or Repair
                            This specification for the DELL Inspiron 7567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7567 boardview and 7567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 7567...
                            09-06-2024, 08:01 AM
