Dell e6440 no display and shut down
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Dell e6440 no display and after some time shut down
    The duration when power on some measurements are as under: on adapter, battery removed
    (however when it gets shutdown, voltage are available just 19v, 3/5v)
    19v ok
    Ldo ok
    3v/5v ok
    Ram 1.35v and 0.67 vtt OK and DRAMRST 3.3v ok
    Ram pwrgd ok
    Pltrst on pin 22 of WiFi jack 0, however on io 3.3v
    Slp_s3 on io 3.3v ok
    Slp_s4 on io 3.3v ok
    IMVP_Pwrgd on io pin 3.3v ok
    PL700 battery/charger coil 13.54v
    PL701 coil 19.67v
    PL600/PL601 (PWR_+GPU_CORE) 0. 86v
    PL 502/503 (+VCC_CORE) 1.71v but feels to be hot
    PL301 (PWR_+1.05V_MP) 1.07v
    PL201 (+1.35V_MEN_P) 1. 37v
    PU603 (+1.8V_RUNP) 1.82v
    U52/U53 (Flash ROMs) pin 8, 3.3v
    Any guidance please.
    Schematic is attached
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell e6440 no display and shut down
    All the readings seems good.Are you sure DRAMRST# is 3.3V?? It should be 1.5V. Bios flashed from known sources?? Ram Stick swapped??
    • usyusy
      • Sep 2021
      • 171
      • Pakistan
      oh sorry boss, it was same as Ram voltage i.e 1.35v. Ram Stick was swapped. Bios was not flashed. which bios should i program? EC or Main Bios? also i have noted two bios U52/U53 (Flash ROMs 64Mb/32Mb on page 18 PCH section) which should i flash. i request in the bios section.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Both the chips should be flashed at one go else there may be version mismatch between the chips.
        • usyusy
          • Sep 2021
          • 171
          • Pakistan
          Sir, how both the chips can be flashed
          • usyusy
            • Sep 2021
            • 171
            • Pakistan
            sir 1 chip u53 (io chip) was flashed successfully, however u52 (bios chip) was giving error as not detected, does this chip seem to be faulty or should do the process after removing from board as i was using on board flashing with cable clip.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I prefer flashing bios chip removed from motherboard.
              • usyusy
                • Sep 2021
                • 171
                • Pakistan
                Sir sorry for late response,
                Main bios was replaced with another one {cfeon q64 104hip} and flashed
                Same result boss., any guidance
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  What is the part number of original bios chip?? Is the new chip listed in bios support??
                  • usyusy
                    • Sep 2021
                    • 171
                    • Pakistan
                    Sir it was w25q64fv and same was replaced again but issue same, I noticed that about 47 sec board remains on but then off
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      The measurements seems all good-so difficult to guess what's wrong. Check carefully for corrosion under microscope.
                      • usyusy
                        • Sep 2021
                        • 171
                        • Pakistan
                        ok sir, thanks so,
                        meanwhile some queries confusing me, if you can please mentor me in this regard:
                        1. Point 1
                        If we remove main bios and powers on, is it dangerous.
                        1. Point 2
                        Both EC and Main Bios pin 8 should show 3.3 even before triggering.
                        1. Point 3
                        "new chip listed in bios support??" where we can check this.
                        1. Point 4
                        If the value of some resister varies from its schematic value, is it problematic (especially for thermal section), e.g Vcore_NTC resister (470K_0402_5%_TSM0B474J4702RE) shows only 240 K,
                        similarly 2nd one (100K_0402_5%) shows only 54.9K. (attached on PCH_DPWROK line).
                        3rd one (130_0402_1%) shows only 64 ohm. (attached on +VCCIO_OUT & VIDSOUT line).
                        1. Point 5
                        If the resistance to ground of some component (Resister especially) seems to be ok on its various pins but its own value,when checked, not matched with the schematic, is it ok or not.
                        1. Point 6
                        what is the ideal resistance to ground of some component cap or resister, e.g more than 200 ohm as a capacitor (0.01U_0402_50V7K) showing 0.099 ohm (2k setting), is it faulty or suspicious.
                        Thanking
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          01. Its not dangerouus to poweron without main bios. But what purpose it'll serve??
                          02.Bios pin8 voltage depend upon whether its 1.8/3.3V chip. It maybe present before trigger(older mobos) and may not be present before trigger on newer mb with Deep Sleep Well(DSW) Technologies.
                          03.Descriptor region of bios. You can use UEFI tool to look there. Somes codes will be listed and you have to google them to findout the actual chip part number.
                          04.Thermal section resistor-Do you mean thermistors?? When you remove a thermal resistors, you should wait for some time and then measure it for resistance as they change values with heat.
                          05.Resistance to GND and value of resistor are 2 different things. Both matters.
                          06.No definite answer for this point. Resistance to GND varies from rail to rail and even from one mb to another. What value of resistance is ok-perhaps no one can give exact measure/answer-It all depends on your experience to conclude whether its value is ok or not.
                          I hope i've clarified whatever i know.
                          • mon2
                            • 14660
                            ..2nd one (100K_0402_5%) shows only 54.9K. (attached on PCH_DPWROK line).
                            The ratio is the same from the original schematic value to actual stuffed value.
                            That is,
                            50% of 470k = ~240k
                            50% of 100k = ~ 54.9k
                            so the result of this voltage divider will remain the same as intended. Likely the vendor ran out of the original component value so they shifted the values to suit during PCB assembly time.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              That is,
                              50% of 470k = ~240k
                              Agree with @mon2. We all change resistor value(specially in AD_ID) to force the mb to work on many occasions. However, whenever, you change resistor value in a voltage divider, the value of R2 should be low ,else the circuit wont discharge completely after power off and you may see symptoms like charging light glowing even after removal of adapter etc.
                              • usyusy
                                • Sep 2021
                                • 171
                                • Pakistan
                                Thank you sir mcplslg123 and mon2 for much valuable guidance and concept clearance.
                                • usyusy
                                  • Sep 2021
                                  • 171
                                  • Pakistan
                                  sir when the pins of two chips of IO were fluxed and hot air was used a little bit, its got stably powered-on. it was taking 1.12A on dc power supply and the keyboard numlock light was working now.
                                  But currently has no LVDS to check its display, and by VGA/HDMI cable display/picture was not apearing on the external lcd (just a light black blink on the screen showing that some signal is going to the lcd when i press FN+External Monitor selection )
                                  is it ok or normal or we should also confirm further with the help of DSO or some other method.
                                  on LVDS connector i measured the following values:
                                  pin 1
                                  5V ALW = 5v
                                  pin 2
                                  Batt white led = 2.02V
                                  pin 3
                                  Batt yellow led = 2.02V
                                  pin 4
                                  Breath white led = 0.12V
                                  pin 5,6,7
                                  +BL PWR SRC = 13.63V
                                  pin 8
                                  PANEL HDD LED = 2.93V
                                  pin 9
                                  DISP_ON = 0V
                                  pin 10
                                  BIA PWM LVDS = 0V
                                  pin 15
                                  CVT LVDS BCLK+ = 0V
                                  pin 16
                                  CVT LVDS BCLK- = 0V
                                  pin 25
                                  CVT LVDS ACLK+ = 0V
                                  pin 26
                                  CVT LVDS ACLK- = 0V
                                  pin 34
                                  LCD EDID DATA = 3.3V
                                  pin 35
                                  LCD EDID CLK = 3.3V
                                  pin 36
                                  LCD TST = 0V
                                  pin 37
                                  3.3V RUN = 3.3V
                                  pin 38,39
                                  +LCDVDD = OV
                                  pin 40
                                  LCD CBL DET# = 3.3V
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    LCDVDD is zero and thats wrong?? Are you getting a milky white display on internal screen??
                                    • usyusy
                                      • Sep 2021
                                      • 171
                                      • Pakistan
                                      Yes sir, lcdvdd seems to be zero, actually I have no lvds or internal screen, only board at hand
                                      However tried to get display on external but only black
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        First find out why LCDVDD is zero.
