Asus x442u 3v & 5v drop
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    hi friends, I hope here someone can help me with the problem asus x442u which at 3v and 5v voltage drops, this is a measurement on the IC UP9003Q (PU8701)
    pin 12 AC_BAT_SYS:19V
    pin
    pin 6 3VADSW_EN ; 0.34V
    pin 20 5VSUS_EN: 045V
  • mon2
    • Dec 2019
    • 14679
    Re: Asus x442u 3v & 5v drop
    For the rails that are low - remove all power. Meter in resistance mode (2k scale). Then check & post the resistance to ground. Then review if the resistance reading is very low then this is the cause for the voltage drop. May be linked to a shorting cap on the respective rail. If the rail is 0V, check if the regulator is being ENABLED - check if the rail has a valid INPUT to the regulator. Post your updates.
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      I'm a little clueless, do I have to measure the resistance on each pin on the PWM ic, or on each coil on this mobo?
      • Yosua
        • Jun 2021
        • 221
        • Indonesia
        this is the measurement on each coil on the mobo sir
        PL8901(CHG_LX) :505OHM
        PL8701(5VSUS): 425 OHM
        PL8702(3VADSW): 338 OHM
        PL8301(1.8VSUS): 335 OHM
        PL8302(1.05VSUS): 48 OHM
        PL8104(+VCCSA): 18 OHM
        PL8102(VCCCORE): 5 OHM
        PL8101(VCCGT): 4 OHM
        PL9100(NVDD LX1): 14 OHM
        PL9101(NVDD LX2): 14 OHM
        PL8601(1.2VO): 151 OHM
        PL9300(1.35VPHASE): 82 OHM
        there is a change here, on pin +3vao the PWM IC becomes normal 3v, but on the enable pin 3v and 5v it becomes 0.07v
        • mon2
          • Dec 2019
          • 14679
          The +3VA rail appears to pass through PU8801. Measure & post the voltage readings for each pin of PU8801.
