hp g62-355dx help
  • nguroje
    • Feb 2015
    • 14
    • Nigeria
    hp g62-355dx help
    Hi all
    I have this laptop (HP G62) with strange behavior to me, it comes up without any sign of bios interface on the screen just blank screen and doesn't load windows. pls can somebody tell me where to start trouble shooting? thanks for any assistance.
  • mon2
    • 14002
    Re: hp g62-355dx help
    Hi. Do you see any backlight on the display ? Any fan spin? Turn on lights or beep sounds ?
    If not, start with the adapter. Is the adapter a good adapter ?
    Did this laptop work before you received it ? Any liquid damage ?
    Do you have a multimeter and soldering iron tools ? To make measurements on the logic board.
    • piernov
      • Jan 2016
      • 4435
      • France
      Rs880m
      • nguroje
        • Feb 2015
        • 14
        • Nigeria
        thanks for the reply mon2 and piernov
        No. I connect the laptop to external monitor no changes, fan is ok
        I have been using the laptop before it developed the problem.
        piernov
        pls do you have schematic?
        • SKP
          • Jan 2022
          • 18
          • Finland
          My reply was deleted, I'd guess something to do with a YouTube link.
          I sent you a PM.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
          • ipatch
            ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
            by ipatch
            i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
            08-24-2024, 02:36 PM
