Asus x442u cant use adaptor
  • mcplslg123
    replied
    Re: Asus x442u cant use adaptor
    Originally posted by Adenitz
    Yosua, your are right, it doesn't make sense to measure and expect any voltage on ACN and ACP pins when the MOSFTET is blocking the input voltage. This clearly can be seen in the attached file (extract from the datasheet).
    The voltage on source(pin1-2-3) of 1st mosfet goes to CMSRC pin of charging ic. You should have +19V on ACN/ACP even when voltage is not crossing the 1st DC-IN mosfet. Gate voltage will be pulled high to 24V approx when ACDET is within range,ACN/ACP is 19V and CMSRC has 19V. So dont be foxed with gate voltage for now. Once again i repeat, you need to find out why ACN/ACP is not 19V. Thats the logical 1st step.
    Its your choice to seek other's opinion and i respect that.
  • Yosua
    replied
    Originally posted by mon2
    See attached. Do you have a battery attached ? If yes, remove it.
    Pin #15 is an active LOW signal. If LOW, then the charger IC believes the battery is attached and will DISABLE the first 2 mosfets from the adapter.
    Try this, take the ACDET signal which is ~2v6 -> use a wire and attach it to the pin # 15 of the charger IC = BATPRES#.
    Remove the battery and use only the AC adapter. Test again. Post your results.
    Summary: We are attempting to change the logic level on BATPRES# line to make the charger IC turn on the first 2 mosfets.
    This is getting messy...check the voltage on the RTC coin cell battery (CR2032). Replace it with a known good battery and test again.
    The power sequencing charge in the posted (similar) Asus schematic notes that the RTC_BAT has to be the first power up rail.
    I've connected it from PR9013(acdet) PIN 1 to PR8930(battpres#) PIN 2 but the voltage drops 0.98v sir
  • mon2
    replied
  • Yosua
    replied
    What are the details of your power adapter ?
    Voltage ? Current ?
    Is it the official Asus power adapter ?
    yes sir i use the original adapter from asus and the output is 19v 1.75A
  • mon2
    replied
    Voltage ? Current ?
  • Yosua
    replied
    From post # 2:
    Measure and post the above readings from the first 2 mosfets.
    thanks sir for your little time, this measurement is using diode mode on a digital multimeter
    fet 1
    s-d = 471 ohms
    d-g = does not appear
    s-g = does not appear
    fet2
    s-d = 482 ohms
  • mon2
    replied
    From post # 2:
    1) remove all power. Meter in resistance mode. Check the resistance across each front side mosfet.
    Source and drain
    Source and gate
    Gate and drain
    Look for low resistance values which means the mosfet is damaged.
  • Yosua
    replied
    usyusy is right, you need first to check whether 19V is present after 1st and 2nd MOSFET.
    1st and 2nd MOSFETS are (judging from the attached boardview) labeled:
    PQ8901 and PQ8902
    Resistors PR8936and PR8934 are both 4.02 kohm just like shown in "Typical application" section posted above. you batter charger IC is PU8901
    PRS8901 is a current sensing resistor (10 mohm)
    ADCDET should be little above 2.5V.
    thank you sir, but previously I explained that 19v only appears on the first acfet on pins 5,6,7,8
    and the acdet line on this bq24780s ic has appeared 2.65v
  • Adenitz
    replied
    PQ8901 and PQ8902
  • usyusy
    replied
    +3V LDO will be missing as perhaps 19V is not passing thru on this board. Since 3V PWM is not getting +19V as VIN ,it cant produce +3V LDO. So dont bother about SDA/SCL at this moment. You need to check why charging IC ACP/ACN is not 19V. Thats the 1st step for repairing this mb. Stay focussed on this issue alone till you fix it.
    as advised by sir mcplslg123,
    first of all just check Volt-in section (19v) i.e 1st, 2nd mosfets and CLR voltages and related caps etc.
  • Yosua
    replied
    Few months ago, I have wasted a lot of time and almost ruined the motherboard, but the problem was with the charger. Sometimes it can also be an issue with the charging port itself because of which adapter is not properly recognized. I was stupid but lucky.
    Master Sorin was also caught is something similar:
    https://www.youtube.com/watch?v=AEzoQNNRhBI
    https://www.youtube.com/watch?v=UIkVhi_MkQI
    thanks for your advice sir, but I'm pretty sure that this is indeed a measurement that I'm missing, or indeed that my experience hasn't reached this point yet.
  • Adenitz
    replied
  • Yosua
    replied
    I've also tried to replace the bq24780s ic with another one but the result is still the same, and I'm surprised that the voltages on the vcc and acdet pins have met the requirements for the ic to produce the proper acdrv voltage.
    correct me if i'm wrong or i missed something for this charger block measurement
  • Adenitz
    replied
  • Yosua
    replied
    isn't it if acn and acp are lost because acdrv has not provided voltage to the gate on acfet, so that acfet can't be opened to supply 19v voltage?
  • Yosua
    replied
    ok thanks sir.. i will focus on acn and acl first..., then on which parameters should i check first sir?
  • mcplslg123
    replied
  • Yosua
    replied
    No. The I2C (SMBUS) SDA & SCL lines are not broken but each should have a pull-up resistor. The other side of each resistor should be pulled up to +3v3.
    The +3v3 rail is missing.
    1) See attached. The schematic for this logic board looks to be very close to yours for the charger IC. This should help for this case.
    2) Check the resistor values for the requested parts. Remove all power. Meter in resistance mode. Measure each resistor value.
    you are right bro, the source of sda and scl is +3va_ec which is on the RN305 near EC, after I measured it turned out that +3va_ec was indeed missing
  • Yosua
    replied
    Post a picture of the DIODE you are referencing and will see it can be found in the schematic.
    Where is it on the boardview file ?
    Need to get ready for work...will continue at the office.
    Is the source of sda and scl +3va on pin 5 of the diode?
    because i measure on kbc also no voltage output for sda and scl . lines
  • Yosua
    replied
    is the schematic you gave is suitable for this board?
    the diode is at the top of the board near the battery connector and the code for this diode is PD6001 bro.
    okay I'll wait when you're at the office
