HP Omen 17-w104no dead PCH? Second opinion
  • peku
    • Jan 2022
    • 14
    • Finland
    Re: HP Omen 17-w104no dead PCH? Second opinion
    Originally posted by EdwardGeo
    Unsolder PL2001 (3.3V coil) and measure resistance to ground at 200 ohm mode on multi-meter. do you have equipment and skills for it?
    Thanks for your help so far, appreciate it! Equipment: possibly, skills: well... let's see
    When PL2001 will be de-attached, measure resistance to ground of +3VS5_S and SY8208BSW pins
    Also before desoldering measure all caps and resistors near PU2001 for a short. It seems that this motherboard doesn't have overcurrent protection, so PU2001 could be dead
    So I'm a bit confused after watching different YT videos about this, how can I reliable check for a short in a capacitator that is not removed from the board with just a multimeter, or can it even be done?
    IF COIL IS NOT CONNECTED, DO NOT INJECT VOLTAGE. THE CIRCUIT WILL BE CHANGED AND CAN HARM OTHER COMPONENTS, BECAUSE ONE OF RESISTORS CANT LIMIT CURRENT IF CIRCUIT HAVE CHANGED
    Haven't got my hands on a voltage injector device yet so no worry about that.
    • peku
      • Jan 2022
      • 14
      • Finland
      OK I've checked these and they all seem fine, beep on the correct side etc. Also I found 3.3V on pin 5 of the PU2001 where it's supposed to be and also in some connections out from it like PC2005, see attached pic.
      Should I go ahead with the desolder of PL2001?
      • EdwardGeo
        • Mar 2020
        • 109
        • Ukraine
        Does PL2001 have 3.3v? If not, then the 3.3v driver is dead, or protection of the driver trying to protect the board because of a short somewhere onboard.
        Desolder PL2001 and by NOT powering the board, check resistance to ground of two pins (before coil - this part comes from voltage regulator driver and after coil - this goes to the board)
        • EdwardGeo
          • Mar 2020
          • 109
          • Ukraine
          3.3VPCU is ldo generated voltage to power logic when laptop is not powered on. So good news - your Embed controller is alive
          • peku
            • Jan 2022
            • 14
            • Finland
            Ok finally got around to it:
            From driver: ~4 MOhm
            To board: 0
            • manol278
              • Nov 2017
              • 41
              • greece
              #26
              I have the same problem in Hp omen 17.No power, Led power on, cpu cold, 3.3V at the power button ok,PU2001 is hot, 3.3V on pin 5 is ok. Any solution found? I have changed PU2001 but the same...
              • peku
                • Jan 2022
                • 14
                • Finland
                #27
                Hmm almost the same but I have no leds on. Just realized EdwardGeo who has helped in the thread lives in Kyiv :/ so he probably has bigger concerns than our motheboards...
                • EineWildeStehlampe
                  • Jun 2021
                  • 13
                  A lot of weird suggestions here. There is obviously a low resistance reading both on the 3.3v and 1.05v switch mode coils. It's a dead PCH with almost 100% certainty. Inject 3v on the 3.3v coil and feel the PCH heat up if you want to confirm it.
                    • Jun 2021
                    • 13
                    Here's the boardview if you don't believe me
                    • manol278
                      • Nov 2017
                      • 41
                      • greece
                      #30
                      3V to PL2001? Must desolder before? 3v 1a is enought?
                        HP OMEN OMEN by Desktop PC - 870-118na OMEN 870 i7-6700 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-118na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-118na boardview and OMEN OMEN by Desktop PC - 870-118na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-12-2024, 03:44 PM
                        HP OMEN X OMEN X by Desktop PC - 900-030 OMEN X i7-6700K Specification for Upgrade or Repair
                        This specification for the HP OMEN X OMEN X by Desktop PC - 900-030 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-030 boardview and OMEN X OMEN X by Desktop PC - 900-030 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                        This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                        HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        HP OMEN OMEN by Desktop PC - 870-265na OMEN 870 i5-7400 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-265na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-265na boardview and OMEN OMEN by Desktop PC - 870-265na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
