Re: Asus X705mb - not turning on
Power MOSFET's used in buck converters usually have inbuilt diodes from drain to source. Saves the designer from having to add them externally. So you should see in diode test a reading in one direction from drain to source, and open the other. The diode is there to protect the FET from the back EMF of the coil when it switches off.
Take note when metering these out of circuit that diode mode on G-S will switch the FET on and it will then appear shorted D-S.
