LENOVO 310-141bk
  • String2016
    • Nov 2015
    • 2234
    • philippines
    LENOVO 310-141bk
    I need help on this laptop lenovo 310 NM-A751 rev:1.0 , the problem is turns on but screen is black and i see flicker, so i tried replacing good screen same results, tried rehet u5 CHIP its working for a whille, but it comes back again same issue, so tried replacing U5 chip same results.I noticed that on U5 pin4 PCH_ENVDD voltage from 3.3v fluctuating.Anyone can help on this please , attached is the schematic
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Re: LENOVO 310-141bk
    Also noticed PQ801 source is shorting to gate beeping and , could it be this mosfet is the prob?anyone please help
    • String2016
      • Nov 2015
      • 2234
      • philippines
      Anyone can help please
      • String2016
        • Nov 2015
        • 2234
        • philippines
        PCH_ENVDD on the U5 pin4 is fluctuating voltage
        • mon2
          • Dec 2019
          • 14120
          When you have the unit on, press the key caps key on your keyboard - do you see the LED toggle on / off ?
          While on, if you apply a flashlight on the front face of the LCD - can you see any of the graphics on the LCD panel ?
          Does an external monitor work with this unit ?
          Trying to understand if the fault is with the backlight or something else on this unit.
          • String2016
            • Nov 2015
            • 2234
            • philippines
            @mon thanks for the response the unit is working fine before until it stock for a couple of days, its working fine on external on internal screen flashing tried replacing good screen same results, notice U5 PIN4 PCH_ENVDD voltage is fluctuating
            • String2016
              • Nov 2015
              • 2234
              • philippines
              anyone can help?
              • mon2
                • Dec 2019
                • 14120
                If the enable pin for pch rail is pulsing then some current trigger must be surfacing on the logic board. Check the resistance to ground of the rail that is turned on by this enable signal.
                What is the reading?
                • String2016
                  • Nov 2015
                  • 2234
                  • philippines
                  Do you mean the R1 resistor?That is my prob i cannot find where is located
                  • mon2
                    • Dec 2019
                    • 14120
                    No. Remove the LCD display.
                    When you see the PCH_ENVDD signal pulsing, does the LCDVDD_CON rail (pin # 20 & 21) on the LCD connector @ JEDP1 also pulse ?
                    • String2016
                      • Nov 2015
                      • 2234
                      • philippines
                      Problem solved, R1 resistor is the culprit replaced it and its working fine now
                        Lenovo 3000 Series Schematic
                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                        3000 C100 laptop with Braille keyboard
                        Lenovo 3000 C
                        C100, C200 - 15-inch XGA screen
                        Lenovo 3000 N
                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                        N500 - 15.4 inch screen.
                        Lenovo 3000 V
                        V100, V200 - 12.1-inch WXGA models
                        Lenovo 3000 G
                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                        10-04-2024, 06:05 AM
                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                        09-06-2024, 06:40 AM
                        This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                        09-06-2024, 06:06 AM
                      • derradji89
                        Need help Lenovo MIX 320-10lCR domaine name SERCOL
                        by derradji89
                        Hi everyone 🤗
                        I have a Lenovo MIX 320-10lCR computer.**
                        1. **Operating System**: Windows 10 ** Education** 64-bit.
                        2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                        3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                        4. **BIOS Chip Reflashing**: Currently,...
                        04-19-2025, 03:04 PM
                        LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                        This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                        09-12-2024, 02:30 PM
