Asus rog gl503v (dabklmb1aa0 rev:a) no display
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    Hi all my friends, I hope you guys can help me to solve my problem with this ASUS GL503 motherboard (DABKLMB1AA0 REV:A), this laptop comes with the engine running but not showing on the internal and external screens, I've tried changing the ram and trying to flash the BIOS ic but this problem still hasn't been solved, the initial condition of the fan is on and the capslock light can be on, but after I flash it with the new firmware instead only the keyboard light turns on every time I connect the charger (without pressing the power button) and the fan turns off, the capslock doesn't work either.
    I hope colleagues can help me and guide me, I thank you very much.
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: Asus rog gl503v (dabklmb1aa0 rev:a) no display
    when the battery is disconnected and there isn't a rtc batt the system has this behaviour: 1 - start 2 - shut off 3 - start again 4 after a couple of seconds if all is ok the lcd go on
    This behaviour with a good bios, EC and no hardware problems
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      thank you for the time you have for this friend, I'm already compatible with RTC and it's still like that, is it possible that the bios firmware I'm using is not with this mobo?
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        If there is a rtc batt on mobo disconnect it after a bios programming.
        regard bios, open a thread in bios request forum, attach your original bios dump if you havea nd I try to help you.
