HP Pavilion 17-ab091ms - white charging light, but no power
  • BMCappelletti
    • Nov 2021
    • 152
    • Brasil
    #61
    Re: HP Pavilion 17-ab091ms - white charging light, but no power
    First, confirm what i have described. If it's so then AD_ID needs to be checked.
    Hi.
    Just tried it. Nothing happens. Just like pressing the power button.
    I don't know why I saw it goes off and on the other time. Maybe I shorted something different or even it was just my mind. I tried only once back then.
    • tksalalah@gmail.com
      • Nov 2021
      • Oman
      #62
      try to find of mosfet no 1 and to and check volt drain and source with multimeter connect negative probe to any ground on circuits and red brown to source of mosfet and drain
      • BMCappelletti
        • Nov 2021
        • 152
        • Brasil
        #63
        I don't remember if I answered that or not.
        The mosfet seems to be PQ1002. I have 19.8V on pins 1, 2, 3, 5, 6, 7, 8. And 17.1V on pin 4.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          #64
          Originally posted by BMCappelletti
          Hi.
          Then perhaps AD_ID is not the issue here. Btw, Have you flashed bios??
            • 21968
            What is the part number on top of the mosfet.
            • BMCappelletti
              • Nov 2021
              • 152
              • Brasil
              #66
              Not yet. I just received a Ch341a programmer and someone told me it could kill the eprom, cause it outputs 5V instead of 3.3V.
              And if I do it without removing the chip from the board (using alligator clips) I could kill more stuff then only the eprom.
              Still deciding if I'll take the risk or not.
              • BMCappelletti
                • Nov 2021
                • 152
                • Brasil
                #67
                It's on previous posts.
                  • 21968
                  Have you checked the traces for corrosion,theres some darker parts on a few,also pins 109,110,111 on the kbc look a bit blackened
                  • BMCappelletti
                    • Nov 2021
                    • 152
                    • Brasil
                    #69
                    I noticed that. And I cleaned it with IPA.
                    • BMCappelletti
                      • Nov 2021
                      • 152
                      • Brasil
                      #70
                      Well, I reflashed the BIOS and... nothing different. So, I injected 1.2V on the shorted capacitors PC6009 and PC6010 (assuming they are really shorted) and the board immediately pulled 4.4 amps from the injector. And started going lower, until it was stable at around 1.4 amps. Question: is it normal to have that drop? Or should the amps pulled be stable? I could not feel anything hot on the board.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #71
                        You mean amps or mA(Milliamps)??
                        • BMCappelletti
                          • Nov 2021
                          • 152
                          • Brasil
                          #72
                          Amps. Not mili.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #73
                            This whole mb will run on less then 1A consumption. I'm afraid when current consumption was 4.4A ,its very likely SOC got killed as the injection point is very near to SOC.
                            • infozizou
                              • Nov 2021
                              • morocco
                              #74
                              you have volt in Coil of cpu and coil of ram?
                              • BMCappelletti
                                • Nov 2021
                                • 152
                                • Brasil
                                #75
                                The only coil with any volt is the one next to the battery connector, where it has 3V if I'm not mistaken.
                                The rest is all zero.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #76
                                  The question doesnt arise when mb is not even switching.
                                  • BMCappelletti
                                    • Nov 2021
                                    • 152
                                    • Brasil
                                    #77
                                    I re-assembled the laptop, just because everything apart was taking too much space in here and I needed to do other stuff. And... well, I didn't quite remember it, but with the battery installed the light is orange when the charger is connected, like the battery was being charged. If I remove the battery and connect the charger the white light comes up. Of course it does not turn on in both occasions, but I didn't remember an orange light was present when the battery was connected.
                                    Does it tell you anything different?
                                    • infozizou
                                      • Nov 2021
                                      • morocco
                                      #78
                                      ok u have shematic board ? you need to check resistance in circle of power system this resistant who enable ic power
                                      and check voltag of coil .
                                      or you need to re program super io whiout remove it from board
                                      • BMCappelletti
                                        • Nov 2021
                                        • 152
                                        • Brasil
                                        #79
                                        Seems like this is the schematic.
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
