Lenovo T440s (NM-A052) dead
  • reassor
    • Apr 2021
    • 181
    • Poland
    So i just got this laptop back after 2 weeks. First time i just cleared cmos and it started now its dead.
    I did some preliminary but i found 260 Ohm on L1 (VCCCPUCORE).
    Is that dead proc/chipset?
    Im asking cause this mobo has me confused to hell.
    Got no 3.3v on Bios 8th leg
    There is +3 and +5 @ S5
  • mon2
    • 14681
    Re: Lenovo T440s (NM-A052) dead
    Link or post the schematics for this laptop, if available.
    If not available, post clear pictures of the logic board starting with where the external power adapter mates sign the logic board.
    The resistance referenced in your post is fine at this time.
    Need to confirm that the adapter voltage enters the logic board and how far the voltage continues. The fact that you have some power rails is a good start.
    Power down and place your meter in resistance mode (200 ohms). Then check the resistance to ground of each coil. Any super low readings? ( Under 10 ohms)
    • reassor
      • Apr 2021
      • 181
      • Poland
      https://www.badcaps.net/forum/attach...5&d=1603128029
      There is schematic. Rail names are so silly wierd,
      could not find any low ohms. (will confirm morning when i go to work and actually measure again.
      Got 3v at power button. Will check power to this silly 2 chip KBC.
      Mainly i was confused that this coil (there is only 1 around CPU) has 260 ohm O_o schematic says its VCCCPUCORE
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        +19V is definitely reaching the mb as you have +3V/+5V S5 rail present. Resistance on vcore area will be low-so that's fine. You need to check the basic requirement for laptop to turn on. Flash known good bios dump first and dont forget to save your existing bios dump.
        • reassor
          • Apr 2021
          • 181
          • Poland
          Bios was first thing i did (got it from this forum). 200ohm on cpu is good? (im not that goot at this yet - still lots to learn). Its an i7 Version. Besides this schematic confuses the hell out of me with the naming scheme. will dive into it tooday if i find time.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            200 Ohms on cpu is definitely good.
            • reassor
              • Apr 2021
              • 181
              • Poland
              thx cause that was wierd for me. I always measured under 10 on CPU's. Even under 1ohm on GPUs.
              Im no expert and it seemed odd to me.
              Didnt have time to get to that mobo in 2 days. So much work :O
              EDIT:
              Read somwhere that 1 of the KBC's (not think engines) likes to die on these boards (it holds all serial numbers and stuff. Ill buy some mobo with broken cpu and will work off that
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                @REASSOR. 4th gen cpu's show resistance in the range of 100-200 ohms and a reading of 10ohms is definitely bad. Newer cpu's like 8th/9th gen cpu's show very low resistance, sometimes even 2-3 ohms.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  10 ohms can be ok on some Haswell-H/M CPUs. For Haswell-U it's more like 50-70 ohms (can be higher).
                  That's with black probe on ground, red probe on ground causes higher resistance IIRC
                  Skylake/Kaby Lake/Coffee Lake are often around 5-6 ohms but can be a bit lower.
                  Lowest I've seen is 3rd gen at 1.5-3 ohms (and even a bit lower on iGPU power rail).
                  That's on laptops, on desktops it can be even lower.
                  • reassor
                    • Apr 2021
                    • 181
                    • Poland
                    thx. tooday i measured again and it shows around 190 ohm.
                    Also board draws around 1.5W - very low amps (0.0024? - something like that)
                    MEC1633L-AUE its getting relatively hot fast.
                    Thx guys. Will let you know ehn i figure out how to dump whats in this kbc and send it to a dude who sells those with your code.
                      Lenovo ThinkPad T440s Grade Barga1n+ Notebook T Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad T440s Grade Barga1n+ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T440s Grade Barga1n+ boardview and T440s Grade Barga1n+ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 08:47 AM
                      Lenovo ThinkPad T440s Notebook T Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad T440s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T440s boardview and T440s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                      09-06-2024, 07:53 AM
                      09-06-2024, 06:45 AM
                      09-06-2024, 06:42 AM
                      09-06-2024, 05:59 AM
