Trying to identify blown component HP ENVY x360 - 15-cn1511na
  • Sephir0th
    • Oct 2020
    • 1289
    Pin12 and 13 at the BQ25708 are the Clock and Data Pins. Here you can confirm the values being low for sanity. Other than that, sure, remove the array and see. If the value stays low, than it still applies what i wrote above. The EC and/or the charging controller is fried on this track.
    the diagnose is already done then. Cure with power supply in combination with thermal camera or by removing possible suspects.
    FairRepair on YouTube
    • pasqui
      • May 2025
      • 10
      • Italia
      Here are the voltage measurements i just took, with the board out of the chassis (so the laptop is off):
      • With only the battery connected:
        • Pin 12: 3.19 V
        • Pin 13: 0.357 V
      • With only the charger connected (no battery):
        • Pin 12: 0 V
        • Pin 13: 0 V
      • With both battery and charger connected:
        • Pin 12: 3.25 V
        • Pin 13: 0.357 V
      • Sephir0th
        • Oct 2020
        • 1289
          • Pin 12: 3.19 V
          • Pin 13: 0.357 V
          • Pin 12: 0 V
          • Pin 13: 0 V
          • Pin 12: 3.25 V
          • Pin 13: 0.357 V
        You were supposed to take resistance measurements, same as before. However, the low voltage at Pin 13 tells already that something is wrong here.
        Once again, charging Controller and/or EC fried.
        Awaiting resistance measurements which would confirm the values which were taken earlier.
        • pasqui
          • May 2025
          • 10
          • Italia
          The resistance is the same 11,67 kΩ! If this BQ chip is fried, could you help me figure out which exact package I should get? I see there are several versions like BQ25708, BQ25708SRN, etc​!
          • Sephir0th
            • Oct 2020
            • 1289
            If it is 11.67 KOhms then it is NOT the same!
            Not sure what you are doing here, but the point was to compare the resistance to GND values of Pin 3 (219 Ohms) and 4 ( 137KOhms) of the battery connector with Pin 12 and 13 of the charging controller.
            And when you share only one value from what Pin is it? From Pin 12 or from Pin 13?
            We can not continue until you start attentive following the advise and until this is sorted.
            • pasqui
              • May 2025
              • 10
              • Italia
              #26
              Hi, sorry for the delay in getting back to you, I've been really busy lately.
              I’ve now done the resistance measurements between pin 3 (BATTERY) and pins 12 and 13 (BQ chip), and between pin 4 (BATTERY) and pins 12 and 13 (BQ chip):
              Pin 3 - Pin 12 = 11,85 kΩ
              Pin 3 - Pin 13 = 11,85 kΩ
              Pin 4 - Pin 12 = 134,1 kΩ
              Pin 4 - Pin 13 = 134,1 kΩ
              Could you please provide me with the exact steps to follow for any further measurements you’d like me to take?
              Thanks again for your patience and support! I really appreciate it. By the way, I just subscribed to your YouTube channel!
              • pasqui
                • May 2025
                • 10
                • Italia
                #27
                I apologize, but i’m still new to this field, so i kindly ask for a bit of patience. That’s also why i’m asking if it would be possible to receive some well defined guidance or support to help me identify the short circuit (I’m sure something is shorted, but I can’t figure out exactly what).
                Anyway, i do have the necessary tools, such as a bench power supply and a thermal camera, so feel free to ask for any test or measurement you think might help!
                Thanks again for your time and help, i really appreciate it! <3
                  HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 12:18 PM
                  HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                  09-06-2024, 11:17 AM
                  HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 06:51 AM
                  HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 06:50 AM
