I have here Hp elitebook 2560p laptop, at first the problem is turns on then goes off and the turns on, so I tried reflash bios i got here, https://www.badcaps.net/forum/showth...light=hp+2560p , the problem solved it show display and working fine, but when i plugged in the charger it goes on directly without pressing power button and when i shut down it does not shut doiwn and the fan at full speed stead not shutting down.it only shuts off when you unplugged the charger with or without battery connected or charger only, I am using original hp charger.Anyone can help on this please
HP Elitebook 2560p problem
Tags: None
Re: HP Elitebook 2560p problem
charging also on battery takes many hours to charge and cannot turn on on battery only when plugged n starts directlyComment
@sephiroth thanks for the response, it charge not normal almost 1day only 24percentComment
What is the behaviour with charger Only, i mean without battery present?
Autostarting too? In my opinion there is likely an issue in the Charging Circuit or BIOS needs to be Changed/cleaned.Comment
yes auto starting too ill tried also clean me bios but still same issue auto starting and when you shut down it will not off fan at full speed it only turn off when chrger unplugged.Comment
If i'm in trouble Like this, i'm doing the Basics:
Checking voltages and internal Résistance of the DCIN-Mosfets, Bat-Fet and Charging mosfet.
Is there a SPI-Flash for the EC/SIO too? It can be the Case that it has to be reprogrammed, If it exists.Comment
Schematic available?? Check PCI_Wake signal. Try removing the lan IC. Check the enable pin on 3/5V DC-DC convertor. Most likely the enable is not removed even after shutdown. Give feedback on these points first.Comment
by wojiHello, can I ask for help with my problem? I have an HP EliteBook 840 G1 laptop and I have this problem - when I turn on the laptop, it usually starts up to 5-6 times ... the keyboard, power button, LEDs always light up, the fan spins and after 1 second the laptop turns off. After several attempts, the laptop turns on and starts to start, but then CapsLock and NumLock start flashing - 3 times and the fan spins at full speed. According to the manual, this is a RAM error - but I have already tried about 10 working modules and always the same error. Has anyone solved a similar or the same problem?...07-08-2025, 02:19 AM
This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:50 AM
HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or RepairThis specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 05:20 AM
- Loading...
