Asus x541uvk memory problem
  • Titoo73
    • Nov 2020
    • 99
    • buenos aires
    Hello friends, I have a problem with an asus x541uvk 2.0 i7 12gb. It entered because it did not turn on and that problem was solved. The thing is that this model comes with 8gb of internal memory and 4gb that go in the socket. When I use the socket memory, the equipment does not show an image but with the internal one. It has already been ruled out that it is not a memory problem. Do you have any ideas to guide me? Thanks
  • mon2
    • 14415
    Re: Asus x541uvk memory problem
    1) when the system is booting normally, check that you are using the latest bios for this motherboard.
    2) remove the coin cell to wipe out the configuration. Then test with the memory stick again.
    3) if still failing, apply the battery and load safe defaults with the bios configuration.
    4) motherboards are specific on which sticks of memory are approved. Check that your memory stick is on the AVL from Asus.
    5) confirm there is no damage to the memory socket pins
    • Titoo73
      • Nov 2020
      • 99
      • buenos aires
      The memory is the original one that comes with the equipment, I will try resetting bios again. The connector looks good
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Clean the socket, check ram voltage.
        Probably a memory controller fault inside cpu
        • Titoo73
          • Nov 2020
          • 99
          • buenos aires
          I have been watching and the tensions have them. It also seems to me that it is something related to the cpu ... that hurts
            Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:21 AM
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
          • AtelierRepa
            ASUS X712JA problem
            by AtelierRepa
            I have a problem with the bios, let me explain.
            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
            06-15-2024, 04:33 AM
            ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
            This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
            09-07-2024, 01:00 AM
