DELL XPS 13 9365 - USB-C problem
  • outsider
    • Apr 2014
    • 104
    • localhost
    XPS 13 9365
    BAZ80 LA-D781P REV:1.0 (A00) 2016-09-13
    The laptop has two USB-C ports. On the port on the left, the charging of the laptop works, but when I connect the flash drive, I immediately have a Blue Screen "driver_verifier_dma_violation". It does not detect the connected mouse / keyboard at all, nor does it display the image on an external monitor.
    On the port on the right there are mass storage devices (flash drives), a keyboard, a mouse etc. It does not display the image on an external monitor.
    Such glitches can indicate faulty CPUs?
    I replaced SSD and install new OS W10, but the effect is the same.
    Visually, both ports look goods.
    • 20873
    Re: DELL XPS 13 9365 - USB-C problem
    The latest XPS models have some known problems with USB-C . Try the suggestions in this article - https://kb.plugable.com/general-supp...cision-laptops
    • outsider
      • Apr 2014
      • 104
      • localhost
      I update BIOS, drivers, try to on airplane mode, turn off WiFi, BT. Nothing change.
      • mon2
        • Dec 2019
        • 14183
        First, check if there is a known factory issue with the model.
        Assuming not, then review the schematics if available.
        Suspecting there is an internal usb hub controller to multiply the usb ports.
        Can you confirm this?
        Usb c is not much different than older designs but need to review this at each stage. How did you view the DMA crash upon docking?
        Try to enter through safe mode of Windows and then dock the usb product. Any crash?
        Could be just crapware drivers for starters.
        Are you able to boot into Windows?
        • outsider
          • Apr 2014
          • 104
          • localhost
          I am currently looking for a schematic / BoardView
          on safe mode it is the same effect
          After restart (Blue Screen when I connect the USB flash drive via OTG cable), I can restart Windows
          When i plug in flash drive (left USB-C port) and turn on laptop, the laptop won't turn on (Blue Screen befor Windows start), on right USB-C it it OK. On left USB-C port, when i plug in flash drive, the LED on the flash drive does not light up
          • mon2
            • Dec 2019
            • 14183
            This board appears to be also known as:
            LA-D781P XPS 13 9365
            I have the schematics for this board but they are encrypted. It is from a paid service we are subscribing to. Perhaps someone else here can supply the PDF?
              • 20873
              @mon2 please see the article link at post #2. This model has known problems. Some boards could not be fixed despite the workarounds and firmware updates (from dell forum and reddit).Dell sent out some boards under warranty at the time. Whats not clear is whats been fixed.Did compal revise the whole board or just replace the USB-C controller chips with revised parts ? .Can you post any screenshots from the schematic
              • mon2
                • Dec 2019
                • 14183
                Ok. See if the attached helps. Certainly can zoom in on other areas but pdf is 58 pages.
                • outsider
                  • Apr 2014
                  • 104
                  • localhost
                  SMDFlea
                  You think he might be guilty in my case the USB-C controller chips?
                    • 20873
                    Originally posted by outsider
                    SMDFlea
                    I don`t know,there might be a revised part for them. Have you checked for any corrosion inside the ports
                      DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                      This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
                      09-06-2024, 12:18 PM
                      09-06-2024, 09:23 AM
                      09-06-2024, 07:50 AM
