ACER Predator PH317-51 - No +3VALWP
  • Sephir0th
    • Oct 2020
    • 1289
    Hello all,
    today i have an ACER, Board Number C5MMH/C7MMH LA-E911P with missing +3VALWP. i found out, it's because of missing 3V_EN Signal.
    No history known. Comes from a household resolution. Maybe it lies for a longer time. The Adapter wasn't of correct wattage, so i just replaced it with a original one, but unfortunately nothing changed.
    +5VALWP, +3VLP_EC, MAINPWON, EC_ON, EC_RST# and LID_SW# are present. As soon as i press the ON/OFFBTN#, i lost all voltages at EC, except +3VLP_EC. i get the lost voltages back, if i steadily press the ON/OFFBTN#. But if i let go the Button, i lost all voltages again.
    Another thing what happens, if i press the Power-Button: The 3V_EN, SPOK_3V, SPOK_3V5V, +3ALWP and +1VALWP comes out just for an blink of an eye.
    i checked all Coils, all Pins of PU401 and all Pins of EC (UB1) for short. Nothing found.
    What i have done so far (19V missing too at the beginning):
    Replaced DC-IN Mosfets PQ303 & PQ304 (Bad looking solder joints)
    Reflowed Charging Controller PU301 (bad looking solder joints)
    Replaced the 3V Controller PU401 (nothing changed)
    Alle tests done with all Subboards and Coin-Cell connected. I have two Switches at the MB (SW2 & SW3). i believe the're only related to battery, is this correct?
    Now i suspect the SIO itself defective and want to replace it. Any other suggestions? Thank you for assistance!
    FairRepair on YouTube
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ACER Predator PH317-51 - No +3VALWP
    3V_EN_R present??
    • Sephir0th
      • Oct 2020
      • 1289
      No, unfortunately Not. It's the Same as with 3V_EN. And If you ask: RB14 and RB15 positive checked for correct Resistance. Also checked DB1 and replaced it, Just to be Sure (i forgot to Tell it before). Any Idea?
      I did Something crazy and jumpered DB1 for Testing purpose. +3VALVP/+1VALWP Came Up, but still too Low SPOK_3V Signal. I reverted the Changes, because i don't want to mess Up the Board...
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Did you removed RB14/15 while jumpering DB1?? If you remove both the resistors, its absolutely safe to jumper db1 for testing purpose.
        • Sephir0th
          • Oct 2020
          • 1289
          Erm, no... I wasn't Aware of this being important. if you're confirming, i haven't damaged the EC by this Test, I'll try it again today with removing These Resistors and See what Happens. Otherwise i Just wait for the Programmer arriving. Need it anyway, because i have one more Board Here, which has Problems with the EC.
          Greetings
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Go ahead and try. I use these sort of tricks to solve a lot of problems without changing the IC. Today i fixed a dell 3542 cedar intel mb-it was not trigerring at all though +3/5VALW was present and all start conditions for sio were met. Bios was also good. Problem was TPS51225 powergood pin was releasing 2.2V instead of 3V. I just cut the track towards IC and jumpered PR4534 so that 3V_5V_POK was released....and it worked like a charm. The same case could've been solved by replacing the IC.
            • Sephir0th
              • Oct 2020
              • 1289
              I Tried it, but wasn't able to establish a high SPOK3V Signal. i replaced the EC and Programmed it succesfully after, but nothing changed...
              In my despair i measured everything around the EC, Maybe Missing "AC_Present" can be a hint? I reprogrammed the BIOS too, Just to be Sure...
              Still nothing. After what i learned so far i never expected to Fail at an 3.3V Coil... But i'm definitely Stuck now...
              My next Steps Would be to replace the DCIN-Mosfets again (didn't replaced it with original spares), the Charging IC (Had Trouble with it at the beginning) and the 3V-Controller the Second time. If it wouldn't Change anything i Would start to replace everything on 3V_EN Rail and Maybe on SPOK_3V Rail too.
              Howewer, i additionally Hope for a good Suggestions.
              The. Charger is original and of correct wattage.
              Ty in advance!
              • Sephir0th
                • Oct 2020
                • 1289
                I just noticed Someone did some Work at the Charging Connector/Cable before. I was thinking about reversed polarity for a second... But can't be case Here?
                • Sephir0th
                  • Oct 2020
                  • 1289
                  Meanwhile amongst other things i replaced the EC and Programmed it succesfully. I additionally flashed BIOS with another dump to Check whether it Changes anything.
                  But today i Had some Progress while Checking components at 3V_EN Rail. After desoldering RB15 i was able to start the Board.
                  Now i get the following:
                  - All voltages present except VCCGT (should be okay because MB has dGPU)
                  - GPU- and CPU-Controller have PGOOD
                  - BIOS isn't Posting (CapsLock-Test) and of course No picture
                  - The Fan Starts for a second, then stops, Board does a Reboot after a few Seconds, again the Fans start/Stop and it stays Like this. No Fans, draws 1 Amps and i have to unplug Power before the heatsing getting too hot.
                  What i Tried so far:
                  - flashed original BIOS Back and also an Clean_me version
                  - Tried another RAM
                  -- fully Assembled the Laptop to Check whether it Changes anything.
                  I still suspect the BIOS, so i want to try more dumps and i'll also reflash the EC Just to be Sure.
                  Howewer any Suggestions are Very welcome. Thank you!
                  • Sephir0th
                    • Oct 2020
                    • 1289
                    After getting it to work with all voltages present (except VCC_GT), and flashing around 10 BIOS Roms (but still no POST & Picture) i did some additional Measurements while waiting for EC Programmer (long story!) Everything seems fine for me...
                    LID_SW# 3.265V
                    EC_VCCST_PG 1.018V
                    THERMTRIP# 1.017V
                    H_CPUPWRGD 1.019V
                    PLT_RST# 3.312V jumping for a few seconds, then stable
                    PLT_RST_BUF# 3.309V
                    PLTRST_VGA#_1V8 1.807V
                    +1.8VSDGPU_AON 1.845V
                    GC6_FB_EN1V8# 1.843V
                    GC6_FB_EN3V3 0.000V
                    1VS DGPU_PG 3.171V
                    1.35VS_DGPU_PG 3.307V
                    ALL_GPWRGD 1.808V
                    except this one here:
                    VR_HOT# 0.049V
                    These weird PROCHOT things... howewer, when i desolder RB19, i have 1.020V at VR_HOT# and clarified, the low signal comes from the EC Pin 103 - VCOUT1_PROCHOT ( 0.000V). But i have no idea why i have a LOW there...
                    Maybe it is related to ADP_I Circuit? Did some measurements there too:
                    VCIN0_PH 2.831V
                    VCIN1_ADP_PROCHOT 0.323V
                    ADP_I 0.950V
                    PH201 reads in-circuit 22K Ohms instead of 100K Ohms.
                    Maybe someone can break down this or could this all be meaningless?
                    • Sephir0th
                      • Oct 2020
                      • 1289
                      I Replaced the EC one more time just to be Sure, but this don't Changed anything in the behaviour.
                      I additionally noticed the PCH got really warm, so i can't Touch it with the outside of my Fingers for longer as 2 Seconds. Checking voltages there don't give me any hint, except +1.0VALW_MPHY which isn't Coming Out, but resistances is around 50 Ohms, so seems to be normal.
                      Howewer i suspect more and more an dead PCH. In this Case i should have to give Up on this Point.
                      I Just want to say thank you for your Patience and your Help on this hard Case.
                      Kind regards
                      • Sephir0th
                        • Oct 2020
                        • 1289
                        This thread is almost 5 months old, but i still don't want to give Up on this one...
                        The Missing +1.0VALW_MPHY wasn't Missing in the end. Just a wrong measurement.
                        So again i did Spend some time on this Board the Last few days and Had some progress while Measuring and working around on this Board.
                        I've found a Bad Dual Mosfet ( QK1 ) related to the Touchpad and now the board draws a Bit more Amps and also the Fans staying at full Speed since then.
                        Additionally i found Out, DDR_DRAMRST# is missing and PM_SLP_S0# really low (~0.4V) but No short there. This is Very weird in my opinion because all voltages and also Signals Like PLT_RST# are present.
                        Of course i've Tested with Known working RAM.
                        Maybe Someone can explain why and hopefully has some ideas what to suspect now.
                        Thanks again!
                          • 21955
                          test voltage and resistance on PU501 pins 5,16,20
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            Unfortunately everything normal there and Q7 not present if this would be the next question.
                            After you have pointed for me out where to measure i noticed too, that S0 should be present when VTT is also present (regarding the small table at page 45 lower left. Weird.
                            Pin 5 - VDDQ - 1.219V - 111 Ohms
                            Pin 16 - PHASE - 1.219V - 113 Ohms
                            Pin 20 - VTT - 0.607V 1.2KOhms
                            So we are back into the direction of bad PCH...? Any ideas left?
