Pegatron D15D Akoya E6416 no power on
  • Conste
    • Oct 2018
    • 235
    Hello all,
    I have another laptop here which has a power problem. MEDION Akoya E6416.
    CPU is i3-5010U.
    When I plug it in it will power on for about 1 second time, but turn of then.
    When I press the power button after about 10 seconds of pause I can start the board again, but it will shut down after 1 second again - sometimes it also stays on longer like 3 seconds.
    When I wait again for some time I can start again and the same thing happens.
    Same thing with battery, charging light comes and for a short time, goes off and starts to charge again.
    BIOS and EC were flashed with a hopefully good dump from the forum. No change at all.
    As far as I could test +3,3V and +5V are present all the time and do not collapse.
    I saw on the connector of the battery that I have around 3 volts all the time and when the charging light comes on it starts to climb - I saw something like 16 volts?! Looks like the voltage is growing too high and then shuts down because of protection? Could this be the issue?
    Could you please help me or do I have to purchase a new board?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Pegatron D15D Akoya E6416 no power on
    It looks like it is a 4S cells battery so it's normal to have a charging voltage of around 16.6V-17.0V. However if the voltage on the battery connector is very low or close to 0V when AC adapter is disconnected (but battery is connected), then the battery is bad. It should be above 13V, preferably around 15V if battery is decently charged.
    You can leave it plugged in overnight to see if it recovers, but battery probably has to be replaced.
    Of course make sure you are using a working AC adapter of correct power rating.
    • Conste
      • Oct 2018
      • 235
      Okay thanks
      But away from the battery - it doesn't even post. What shall I do?
      • Conste
        • Oct 2018
        • 235
        Anyone?
        I just saw that it tries to generate the VCore voltage when the power light comes on, but then it goes off.
        But resistance in both power supplies for CPU is okay, around 50 ohms.
          • 21841
          Which one did you flash it with, can you post your original bios backup in the Bios requests section .
          • Conste
            • Oct 2018
            • 235
            Bios was from here
            https://www.badcaps.net/forum/showthread.php?t=71863
            Both Bios files from you were flashed
              • 21841
              Bios was from here
              It should be ok,i don`t know,only 1 member could be bothered to leave any feedback .
                • 21841
                Have you tried a working AC adapter of correct power rating as piernov suggested ? .
                • Conste
                  • Oct 2018
                  • 235
                  Of course. I used a 90W power supply, label says that only 65W is necessary. Also tried a laboratory supply which can deliver up to 10 amps.
                    • 21841
                    Ok. Check every single mosfet on the board,they`re a known point of failure on cheap pegatron boards.
                    • Conste
                      • Oct 2018
                      • 235
                      How to check them?
                      Where to begin?
                      • samtron786
                        • Aug 2016
                        • 170
                        • germany
                        I also have a Medion Akoya E6416 MD99560 that turns on and works, but at some point it turns off and doesn't turn on straight away, I have to wait hours or a day for it to turn on again.
                        Where is the problem?
                          MEDION AKOYA Akoya E7419 Notebook Specification for Upgrade or Repair
                          This specification for the MEDION AKOYA Akoya E7419 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Akoya E7419 boardview and Akoya E7419 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                          09-06-2024, 07:29 AM
                          MEDION AKOYA AKOYA E6239 Notebook Specification for Upgrade or Repair
                          This specification for the MEDION AKOYA AKOYA E6239 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AKOYA E6239 boardview and AKOYA E6239 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                          09-06-2024, 05:27 AM
                          MEDION AKOYA E2016 F AKOYA i3-6100 Specification for Upgrade or Repair
                          This specification for the MEDION AKOYA E2016 F can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA E2016 F boardview and AKOYA E2016 F schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                          09-12-2024, 02:20 PM
                          MEDION AKOYA P62005 AKOYA i5-8400 Specification for Upgrade or Repair
                          This specification for the MEDION AKOYA P62005 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P62005 boardview and AKOYA P62005 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                          09-12-2024, 02:15 PM
