Asus X555LD Rev 3.6
  • paolotto
    • Sep 2020
    • 7
    • Italia
    Asus X555LD Rev 3.6
    hello everyone I have an Asus X555LD Rev 3.6 motherboard on a notebook violently slammed into the ground. detached PU8101 and does not heat more '. I think it is broken but what I would like to know for now is how can I find the values of the capacitors, resistors, etc. of the elements of the motherboard? i downloaded BoardViewer but i can't find the values for example of PR8116. is it a resistor? what is its value?
  • paolotto
    • Sep 2020
    • 7
    • Italia
    Re: Asus X555LD Rev 3.6
    hello everyone I have an Asus X555LD Rev 3.6 motherboard on a notebook violently slammed to the ground. I unplugged, unsoldered PU8101 and it doesn't heat up anymore. I think it is broken but what I would like to know for now is how can I find the values of the capacitors, resistors, etc. Of the elements of the motherboard? i downloaded BoardViewer but i can't find the values for example of PR8116. is it a resistor? what is its value?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      PR8116-RES 200K OHM 1/16W (0402) 1%
      CYNTEC/RR0510S-204-FN. Its clearly mentioned in boardview.
      • Bonzas
        • 469
        • Indonesia
        you can't find component code on where ? motherboard or boardview ?
        if u mean component code on motherboard, many asus board don't have it.
        on boardview, you can click on the component, see right panel. there's component code
        • ravi_1617
          YY Solutions
          • Jan 2012
          • 343
          • India
          Hi Same board Asus X555LD .(PU8101) UP1589 is heating..
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 343
            • India
            No Reply Any one...
            • paolotto
              • Sep 2020
              • 7
              • Italia
              hello thank you for information but maybe not knowing the program well I can't see the data as described by you. can you give me the succession of the steps to get to see the values? or maybe I have a wrong version of
              boardview? another question the pin 19 of the PU8101 is short-circuited the same refers to PR8116 which has the other ground contact
              is it normal that pin 19 of the PU8101 is grounded? I think not because the diagram says that 5 volts should arrive at that point. ?
              • paolotto
                • Sep 2020
                • 7
                • Italia
                hello and thanks my difficulty is that I can not visualize the value of the components as mcplslg123 wrote me, that is, I can not on boardview to visualize the value of the components
