elitebook 8760W laptop which has a problem with charging
  • mohammed mohan
    • Nov 2017
    • 198
    • z
    Hello can you help
    I have a hp elitebook 8760W laptop which has a problem with charging / the problem is in charge but the charge rate remains 0% / the battery and charger were replaced too, and I changed the BQ 726 it remained the same problem
    I attached pictures of the problem
    These are the special voltages in BQ 726
    Pin voltage
    1 = 19.06
    2 = 19.06
    3 = 19.41
    4 = 19.41
    5 = 3.341
    6 = 2.671
    7 = 0
    8 = 3.360
    9 = 3.360
    10 = 3.348
    11 = 0.147
    12 = 0
    13 = 0
    14 = 0
    15 = 0
    16 = 6.038
    17 = 5.841
    18 = 0
    19 = 0
    20 = 18.33
    Please help, thank you
    Mohammed Mohan
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: elitebook 8760W laptop which has a problem with charging
    Did the laptop run properly from the "new" battery (AC adapter disconnected, when the battery was still charged) and did it report percentage properly?
    • mohammed mohan
      • Nov 2017
      • 198
      • z
      A good battery was placed on another laptop and the laptop was tested on the battery without a charger and when the charger is connected the charge percentage does not increase
      Mohammed Mohan
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ACDRV is not working. Check your first 2 dc-in mosfets and the voltage divider circuit for gate pin.
        • qayyum786
          • Aug 2018
          • 1958
          • INDIA
          Remove "Q14" MOSFET and check on I.C pin NO:- 4 (ACDRV) voltage = ?
          • mohammed mohan
            • Nov 2017
            • 198
            • z
            I removed Q14 "MOSFET
            This is voltage 4 (ACDRV) voltage = 25.83
            Mohammed Mohan
            • mohammed mohan
              • Nov 2017
              • 198
              • z
              Thanks for replying, can you clarify more?
              This is voltage 4 (ACDRV) = 25.83
              Mohammed Mohan
              • qayyum786
                • Aug 2018
                • 1958
                • INDIA
                R83 rasistor value = ?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Is this voltage after removing Q14 mosfet?? Your post#1 shows it at 19V. Can you clarify??
                  • qonma
                    Kuli Solder
                    • Jun 2017
                    • 184
                    • INDONESIA
                    replace ic harging and mosfet too
                    • mohammed mohan
                      • Nov 2017
                      • 198
                      • z
                      Thank you my friends
                      A bug \ "Q14" was found to be replaced by MOSFET
                      Mohammed Mohan
                      • qayyum786
                        • Aug 2018
                        • 1958
                        • INDIA
                          HP EliteBook 8760w 8000 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 8760w can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 8760w boardview and 8760w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook 8760w is accurate,...
                          09-06-2024, 05:27 AM
                        • woji
                          HP EliteBook 840 G1 - memory and MB problem?
                          by woji
                          Hello, can I ask for help with my problem? I have an HP EliteBook 840 G1 laptop and I have this problem - when I turn on the laptop, it usually starts up to 5-6 times ... the keyboard, power button, LEDs always light up, the fan spins and after 1 second the laptop turns off. After several attempts, the laptop turns on and starts to start, but then CapsLock and NumLock start flashing - 3 times and the fan spins at full speed. According to the manual, this is a RAM error - but I have already tried about 10 working modules and always the same error. Has anyone solved a similar or the same problem?...
                          07-08-2025, 02:19 AM
                          HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                          09-07-2024, 05:50 AM
