Acer aapire 3 A315 not turning on
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys, im working on an Acer Aspire
    Board no: C5V01
    LA-E891P
    I have 3.3V and 5v obvious the 19v, when i plug in the charger, the output coil on the charging section is getting hot when i plugin the charger and the battery same time, the board will not turn on, I've never seen a coil getting hot, can it be the 2 mosfets that charges the battery maybe.
    When i plug in the battery alone, the laptop sometimes turns on and work well, but when you plug in the charger, it won't turn on and the coil on the charging section get hot, the laptop shows that it charging when the charger it plugged in, but won't turn on and the coil get hot
  • peste
    • 13585
    • ROMANIA
    Re: Acer aapire 3 A315 not turning on
    remove the battery, connect the charger and turn on the laptop .. see what happens ..
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Thank you brother
      It turned out that the keyboard was the problem,creating a short
      • crearelectronica
        • Jun 2020
        • Colombia
        Originally posted by mnciks11
        Thank you brother
        Hello, how did you solve your problem?
        I have similar equipment with the same fault.
        Thank you
        • mnciks11
          • Aug 2019
          • 345
          • south Africa
          Thank you
          Yes the keyboard was the problem
