HP ZBook 17 G3 wont boot
  • mr.Data
    • Sep 2018
    • 75
    • Netherlands
    When I turn on the ZBook 17 G3 all light go on but I got a black screen en no sign of life.
    Then after a few seconds the charging light starts blinking 10 times. The other light go out. The charging light blinks another 5 times and the laptops shuts down.
    I got a full battery and tried with the charger as well but got the same issue.
    Any suggestions?
  • mr.Data
    • Sep 2018
    • 75
    • Netherlands
    Re: HP ZBook 17 G3 wont boot
    When I take out the bios battery and the GPU the ZBook seems to be rebooting and the fan spins one time every now and then.
    The CPU does not get hot. Should I suspect a broken CPU?
    • peste
      • 12973
      • ROMANIA
      what voltages did you measure? 19v, 5v, 3.3v, etc., give us more details.
      • radegoub
        • Jul 2018
        • 9
        • France
        Hello, I have this problem with an hp zbook 17 g3 laptop. It does not turn on.
        the power button LED stays on, not possible to turn it off by pressing the button and I have 5v at the button.
        sorry for my poor english, i am french.
        please i need help.
        • radegoub
          • Jul 2018
          • 9
          • France
          please can you help me , I have 5v at the power button
          • radegoub
            • Jul 2018
            • 9
            • France
            Originally posted by peste
            hi i look for help please, my laptop won't boot and i have 5v on the power button, what could cause that
            • mon2
              • 14370
              Hi @radegoub.
              Can you post any markings on your logic board ?
              Any history of this unit ? Liquid damage ? You are using the original power adapter ?
              • radegoub
                • Jul 2018
                • 9
                • France
                Originally posted by mon2
                Hi @radegoub.
                yes of course, the motherboard is an APW70 LA-391p Rev 1c, no trace of liquid, all voltages are good, well I think.
                the charger is a 200w hp, but I don't understand why I have 5v at the power button.
                • mon2
                  • 14370
                  Trying to locate the schematic for this unit but the general starting base is to check as follows:
                  Remove all power.
                  Meter in resistance mode (2k scale is good)
                  Check the resistance to ground for each coil (often grey in color) to ground.
                  Looking for any low resistance readings.
                  If found, post the coil location with silk screen markings if known. The coil could mean a defective power rail due to a failed capacitor (shorting).
                  • radegoub
                    • Jul 2018
                    • 9
                    • France
                    Remove all power.
                    I forgot to tell you that the charging light comes on when you plug in the charger, the battery light flashes orange (even though I don't have the battery) and the power button LED lights up dimly.
                    I must also specify that I flashed the bios main and EC (no change)
                    I took the measurements of the coils, resistances and voltages,
                    PL7 13 Ohms
                    PL8 70 Ohm 0.9V
                    PL11 164 Ohms 0V (1.35V I guess)
                    PL33 34 Ohm 0V
                    PL37 0L 0V (charging coil)
                    PL39 0L 3.3V
                    PL40 0L 5V
                    PL42 0L 1.8V
                    PL44 0L 0V
                    PL47 2 Ohm 0V
                    PL48 5 Ohm 0V
                    PL49 2 Ohm 0V
                    PL50 5 Ohm 0V
                    PL51 2 Ohm 0V
                    PL59 0L 19V
                    also I remove the mxm card before measuring
                    Thank you for your help
