Asus K55VD Rev3.0 NO GFX Core Volt !!
  • battery.12v
    • Dec 2014
    • 123
    • NW
    Hello Everyone !! i have this Asus K55VD power on but no display ...
    checked with its repair guide ... all test points are OK expect one GFX_CORE ... any idea please
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus K55VD Rev3.0 NO GFX Core Volt !!
    This mb is known to have this issue when bios gets corrupted. Flash a known good bios-it is very likely to solve your problem.
    • battery.12v
      • Dec 2014
      • 123
      • NW
      i flashed one but no luck i will try another one
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Post your original bios backup in bios section. We can merge it with asus webupdate for bios. that way you can rule out bios issue.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          What is the resistance on GFX coil??
          • battery.12v
            • Dec 2014
            • 123
            • NW
            4.5 Ohm
            • battery.12v
              • Dec 2014
              • 123
              • NW
              Asuus K55VD No GFX_CORE ... i need some guidance in troubleshooting it .. i flashed Bios Three Times but same issues
              GFX Pgood is Low , GFX RST is low
              • battery.12v
                • Dec 2014
                • 123
                • NW
                BAD BOARD
                pin 10 0.59V GFX_IMON
                pin 11 0V GFX_VSEN
                pin 17 0V H_PROCHOT_S#
                pin 19 0.79V GFX_TSEN
                pin 23 0V GFX_RESET
                pin 28 3.3V CPU_VRON_PWR
                A Working BOARD
                pin 10 0.61V GFX_IMON
                pin 11 1.02V GFX_VSEN
                pin 17 1.05V H_PROCHOT_S#
                pin 19 0.86V GFX_TSEN
                pin 23 0.0V GFX_RESET
                What Signal i have to check First ???
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  dramrst on pin 30 present??
                  • battery.12v
                    • Dec 2014
                    • 123
                    • NW
                    DRAMRST# present 1.53V
