A2159 820-01598-06 USB ports
  • MalMcK
    • Jan 2019
    I have this liquid-damaged MacBook that has no schematics available yet (so far as I know). I've cleaned up the corrosion as best I could, and it worked after that. Then I unplugged it and tried to connect the battery to see if it would charge it. The thing wouldn't come back on, no matter what combination of battery vs no battery I tried.
    I have a USB C ameter and noticed that one of the ports reads 20V and 0.08A, while the other reads 5V and 0.27A. While I've forgotten more about electronics from when I was a kid than I care to mention, I wanted to run it by you guys to see if you think it's a short on some USB controlling IC. I think it has one IC for each USB port, right?
    Is there any motherboard that's similar enough to this one that actually does have schematics available?
    Thanks in advance.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: A2159 820-01598-06 USB ports
    This board has a layout that no board used before so chances are you won't find a matching boardview. USB-C controllers are CD3217 rather than the CD3215 found on earlier models and we don't know what are the differences and they're not available to buy. For schematics, maybe you'll find similarities with 820-00850.
    In any case it sounds like one of the LDO of the CD3217 that has 5V/0.27A is shorted to ground, so chances are the CD3217 is bad.
    But without parts available there's not much you can do… this one will probably have to sit on a shelf for a few more months at least.
    You can always measure voltage and resistance to ground on the capacitors near both CD3217 and compare if the layout is similar enough around both CD3217 so you can find the line that's causing a problem, and inject some voltage if there's a short to ground.
    • MalMcK
      • Jan 2019
      Excellent thoughts, Piernov. That gives me a few more things to be getting on with before I put it on the back-burner. My suspicion is that I need to reball the CD3217.. and then hope it was just crud or a corroded connection underneath. Now I just have to find a stencil that this chip will fit with!
      Thanks very much for your help. If I get it fixed, I will post details here to potentiall help someone else.
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
        Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
        09-06-2024, 09:40 AM
