I need help on this Acer E1-510 la-a621p, the problem is turns on but no display.I have already replaced the bios chip and flash the bios with the one here in this forum, but still no display, cpu is warm.I flashed the main bios only, because when i try to flash ec using svod3 it says pins false, but i check the pins with connectivity is ok.i have 0.9v on the coil near cpu.voltages on the coil have 3.3v and 5v near the ram area.anyone please
E1-510 NO display
Tags: None
Re: E1-510 NO display
Make sure you're using known good DDR3L.
No backlight/no image even on external? Pressing caps lock key doesn't trigger caps lock LED? Not POSTing at all?OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
already tried replacing with good ram ddr3l still persist, blue light pressing and fan spinnnig but no caps lock light, no image on both internal and externalComment
PJ504/506/601,PH801/802 Voltage??PU801 PIN 2/21/15 voltage?? 1.35V present on Pin30 of Dramslot??Comment
PJ504=1.35V
PJ506=0.6V
PJ601=1.04V
PU801 PIN2 3.3V
PIN15=3.3V
PIN21= 5V
DRAMRST= 0.2V
I cannot find PH801/802 on the boardComment
DRAMRST should be 1.3V. Measure voltage on all pins of pu501 and post here.Comment
pu501
pin1=0v
pin2=0v
pin3=0v
pin4=0v
pin5=1.35v
pin6=0v
pin7=3.1v
pin8=3.2v
pin9= 0.9v
pin10=1.3v
pin11=5v
pin12=5.1v
pin13=5v
pin14=0v
pin15=0v
pn16=1.3v
pin17=1.3v
pin18=4.9v
pin19=1.3v
pin20=0.6vComment
I think the missing voltage is the LGATE supposed to have 1.35v and its connected to pin4 of PQ503, i measured pin 4 missing 1.35 vComment
Try other BIOS dumps.
Note that with dirty ME/TXE, it may take a minute for display to turn on.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
@piernov i have downloaded the bios here is this forum as many confirmed it is working for this model and board , already replaced the chip. the problem is still no displayComment
Your measurement of PU501 seems little confusing. If you have 0.6V at pin20 you should have 0.6V at pin2 as well.Pin4 REF voltage is missing.PIN6 FB is 0V which is wrong. Without ref and fb working, your fet gate will not open. If you have a same spare ic try replacing it.Comment
i double checked again the measurement yes pin 20=0.6v pin2=0.6v and pin 4 as well. i cannot find the same chip is there any replacement value on this?Comment
RT8207MZQW=J7
So your J7 ic is likely bad. Was it new or you pulled from scrap mb??Comment
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Aspire Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) boardview and Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) schematic....09-07-2024, 01:00 AM
- Loading...
