asus x555uj strange behaviour
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    asus x555uj strange behaviour:
    1 - reprogrammed bios -> it turn on with delay
    2 - clear ME -> delay remain
    3 - reprogrammed with another bios -> it turn on with delay
    4 - clear ME -> delay remain
    So after other checks:
    1 - the delay time it's not the same
    2 - with an hard disk from another asus -> it stuck at asus logo , sometime it reboot
    3 - easyflash don't start -> blank screen and return to bios screen
    4 - the battery led remain red after I disconnecting battery
    I wish there is not a problem with PCH and I wish the issue came from ram or ite, any suggest ?
    • 21936
    Re: asus x555uj strange behaviour
    Try booting from a linux cd/usb with the HDD board removed. If the delay is gone check,resolder or replace j3903 on the HDD board.
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      The system is not stable, this is the post code list after some shut and start
      , I take last bios from this forum and and is considered working
      system cold
      -> push start
      -> code 35 (20 sec)
      -> code 79 (30 sec)
      -> asus logo
      -> code 78 (stuck at)
      system hot
      -> push start
      -> code a9 (stuck no image but led on)
      -> push to shut
      -> immediately start
      -> code a9 (30 sec)
      -> code a6 (bios screen) this post is correct
      -> push to shut
      -> correctly shut down
      -> push to start
      -> push to shut
      -> immediatly start
      -> code a6 (after 70 sec bios screen)
      -> push to shut
      -> remain off correctly
      -> push to start
      -> code 79 (20 sec)
      -> inser linux pendrive
      -> push to start
      -> code 79 (asus logo and stuck at for 60 sec)
      -> restart itself
      -> code 79 (asus logo -> blank screen -> stuck at for 60 sec)
      -> restart itself
      -> code 62 (blank screen, stuck at)
      • piernov
        • Jan 2016
        • 4439
        • France
        If it has soldered-on RAM, try with and without additional RAM stick.
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          I wanted to disable the onboard ram, but reading some posts and having done some tests in the past I decided that it was better not to try. I have a zenbook with a good video card and I preferred to put in the i7 of the x555uj .
          Fortunately, it starts up correctly and charges the battery.
          I can say that the problems were not about the processor and the bios, probably the ram was the cause.
          But changing the dimm_sel really excludes the bank of ram ?
          has anyone really managed to disable the bank?
