samsung np350vsc problem
  • hazim
    • Mar 2016
    • 62
    • egypt
    i'v samsung np350v5c-a02ae qcla4- la8862p rev 2.0
    when i press power lap power on and automatically entering set up
    with out pressing any key
    a adjust bios setting and rest but still entering set up
    when i press f10 and choise booting from hdd
    lap entering windows and work will
    when i restart i back to problem again
    battery volt 3 and lap save date and time
    i need your help
  • hazim
    • Mar 2016
    • 62
    • egypt
    Re: samsung np350vsc problem
    SOLVED PROBLEM i re flash bios rom and ec then laptop work very good
    i find bios in our forum badcaps
    thanks a lot
      09-07-2024, 05:50 AM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • alro7779
      Samsung UN55MU6103F video problem; has colored stripes on the display
      by alro7779
      Hello, everyone!
      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
      09-27-2025, 11:29 PM
      09-06-2024, 11:40 PM
