Asus k55vd usb problem
  • thinkfast76
    • Mar 2017
    • 46
    • italia
    I have a problem with this notebook Asus k55vd, after a thunderbolt have stopped working USB 3.0 ports connected with the flat, after a few months even those soldered to the motherboard have stopped working. Actually they feed but the notebook does not recognize the connected USB device.
    I have no idea what to go check.
    I enclose the border view https://www.badcaps.net/forum/showthread.php?t=72684
  • boyebaran
    • Sep 2015
    • 249
    • iran
    Re: Asus k55vd usb problem
    hi
    please measure voltage r3033 to gnd.
    you can check main 5volt in usb3 jack .(D5201 pin 5)
    • thinkfast76
      • Mar 2017
      • 46
      • italia
      Originally posted by boyebaran
      hi
      Thx mate i will try
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
      • AtelierRepa
        ASUS X712JA problem
        by AtelierRepa
        I have a problem with the bios, let me explain.
        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
        06-15-2024, 04:33 AM
      • greg1985
        Asus dabkxmb18b0 rev.b bios problem
        by greg1985
        Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
        I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
        I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
        10-20-2025, 11:34 AM
      • boticario
        problem with asus tuf A17 FA707NUR
        by boticario
        I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
        The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
        After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
        I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
        10-18-2025, 04:37 PM
      • boticario
        by boticario
        10-14-2025, 08:38 PM
