Dell Inspiron 15 5570 plug in not charging
    hello plug in not charging problem on CAL50/
    DAL10 LA-F115P...so need schementics or
    solution for that..please help me...thanks in advanced
    Re: Dell Inspiron 15 5570 plug in not charging
    hello anyone have any idea on this...???
      schematics cannot be found at the moment. this PSID error you can track and check components between DCIN PSID pin SIO. there should be mostly 33ohm resistor, transistor.
      let me know the SIO number.
        thank you...I will check tomorrow and let sio number
          Thanks bro....transistor found faulty on bsid section......but how to make replacement since I don't have schementics to view transistor number...???can we bypass that....???
            Replace with 33ohm rating
              pls can you please defind the transistor witch one i have same problem bro
                I also need the number of transistor or equivalent transistor. I think the part no of this transistor is CG5 but I can not find the datasheet of this transistor or equivalent. Please help me also to find the equivalent transistor. Thank You
                  Hello, I have Inspiron 5570 suddenly stop charging, any idea to how to fix it? It stops charging after plugged USB-C to DisplayPort cable on a external screen. Thanks in advance
