LENOVO U330 DA0LZ5MB8B0 Quanta LZ5 REV:D
  • kokono
    • Jun 2018
    • 203
    Re: LENOVO U330 DA0LZ5MB8B0 Quanta LZ5 REV
    i removed PU6 and so now i dont have 3.3v_ALW2
    but i can remember also with PU6 , dont hat 3.3v_ALW2
    • kokono
      • Jun 2018
      • 203
      Originally posted by SMDFlea
      What voltage are you getting on +3.3V_ALW2 ,and have you attatched the (good 3V) CMOS battery
      yes, also with CMOS battery
        • 20884
        What voltage do you get at the DC-IN connector, pin 5
        • kokono
          • Jun 2018
          • 203
          0v
            • 20884
            Originally posted by kokono
            0v
            0V with the laptop charger ? , if yes then try a different charger. Try starting from a charged battery .
            • kokono
              • Jun 2018
              • 203
              i think this 0v ist normal for ID pin because i dont have 3v
              Originally posted by BlueMidnight
              There will be no voltage on the ID pin if the 3V switching regulator on the board isn't powered up. And yours won't be since your main power rail isn't working.
              • BlueMidnight
                • Jan 2015
                • 489
                There are some irregularities with your PU7 measurements that should be checked.
                - Pin 4 is designed to be raised ~6V higher than pin 3 to turn on the input FETs, but it's only barely higher. Which means it's not in the off state. But it's not fully in the on state either.
                - Pins 1 and 2 should not be higher than pin 3. The exit side of PQ21 shouldn't have a higher voltage than the entrance. Is voltage leaking through from the gate pin?
                If these are steady voltages (not jumping around such that the measurements on different pins aren't entirely correlated with each other since they were measured at different moments), then something isn't right in this area. Check for a gate-drain short in PQ21 for starters.
                If something like that were the case, then there would be voltage on "VA2", but there would be no actual ability to provide the sort of current the buck regulator needs to operate once it's connected to anything on its output.
                • kokono
                  • Jun 2018
                  • 203
                  YEEEES
                  PQ20 ist short
                    • 20884
                    Yes, i was looking at the PQ19 area to see if that was pulling the voltage down. I`m glad you`ve got it sorted out .Whats the voltage out of PU6 now is it more than 7V
                    • kokono
                      • Jun 2018
                      • 203
                      i replaced mosfet PQ20 and now i have 3.3v and 5v and when press start button , i can see that led blinking for 1 sec and shutdown
                      i think have short circuit.
                      any idea ?
                      • kokono
                        • Jun 2018
                        • 203
                        i checked all line voltage, without short circuit
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          Well that's progress at least. It couldn't hurt to measure PU7 pins 2,3,4 again.. just as a sanity check to make sure everything looks 100% okay there.
                          But also, make sure you check the power rails both before and after the load switches. For example, +3.3V_DSW becomes +3.3V_RUN, but only when PQ7 turns on. Likewise, +5V_ALW goes through PQ15 to become +5V_RUN. Etc, etc. There can be a short on one of those switched rails, and the board doesn't freak out until it actually tries to turn on the load switches.
                          This is also about the time the system firmware would come into play. There are a bunch of other possibilities really.
                          when i received this laptop ,i found a bad capacitor , i removed it
                          Out of curiosity, which capacitor was this? The capacitor, the FET, and now something else seem to be bad. To narrow down the problem, it's worth thinking about how these things might be related.
                          • kokono
                            • Jun 2018
                            • 203
                            Pin4 = 26V
                            Pin2 ,3 = 20v
                            for test, i removed PQ7 and PQ15
                            ist same, LED blinking and after 1s shutdown
                            PC136 war defect complete
                            • kokono
                              • Jun 2018
                              • 203
                              this voltag ist normal ?
                              • BlueMidnight
                                • Jan 2015
                                • 489
                                Testing for a short to ground on both sides of PQ7 and PQ15 is enough. Obviously, it won't want to turn on without them.
                                When the board wants to read the AC adapter type, it has to turn on PQ19B. To do that, it needs to turn off PQ19A. To do that, ADAPTER_ID has to be 0V. But it only needs to do that when it wants to determine the type.
                                The 2 component failures do seem related at least. When the capacitor shorted, it could have cause a current/voltage pulse that damaged the FET. The other capacitors in that area would be an obvious short, so they are probably fine. PQ21 seems to be turning on okay so far. PQ13 too.
                                So maybe PR102 could have been damaged by excessive current. If its resistance has increased slightly, the board might think there is too much current flowing and shut down.
                                But there isn't much else in that area to go bad without noticing it easily. So the problem might be elsewhere.
                                What happens if the board is turned on with battery power only? (assuming you have the battery and it has enough charge) And if the AC adapter and battery are plugged in together, does it charge the battery?
                                • kokono
                                  • Jun 2018
                                  • 203
                                  +PWR_SRC ist ok (equal 9V) and ist stable even when press start button.
                                  and also +3.3_DSW and +5v_ALW ist fix even when press start button.
                                  but i can see with start button, that +3.3v_RUN and +5V_RUN function but after 1s shutdown
                                  i think ist elsewhere
                                  ist same also with battery
                                  yes, it can charge battery perfect
                                  • BlueMidnight
                                    • Jan 2015
                                    • 489
                                    Yeah, it does seem to be elsewhere. Try measuring HWPG (U20 pin 124) as you are trying to turn it on. Does it ever go high?
                                    • kokono
                                      • Jun 2018
                                      • 203
                                      after turn on motherboard, i can see 3.3v and after 1s null
                                      Edit :
                                      with and without PQ7 & PQ15 ,behavior is same
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        It is actually getting really far along then. Does PLTRST# go high to turn on the CPU as well? (the only place to measure this is CN14)
                                        • kokono
                                          • Jun 2018
                                          • 203
                                          No. all time ist null
                                            Lenovo E130 Quanta LI2 REVD,E,F Schematic & Board View
                                            Lenovo E130 Quanta LI2 REV D,E,F Schematic & Board View...
                                            10-02-2024, 02:10 PM
                                          • davidtgbe
                                            LENOVO U330 DA0LZ5MB8D0 Quanta LZ5 REV:D
                                            by davidtgbe
                                            Hi there,
                                            I have this laptop which is not powering on/charging with the AC adapter plugged in.
                                            At some point, battery ran out and the laptop did not charge anymore and did not turn on either.
                                            First things checked in the MB:
                                            - Visual inspection. All clean.
                                            - 19V on AC adapter -> OK.
                                            - PD11, PF2, PQ20, PQ21 -> OK (fuse, diode, mosfets)
                                            - C211 shows a short between GND and MX7 line to U20 (don’t know IT8587 internals, may be it is normal).
                                            - PC65 shows a short between GND and 3.3V_ALW2
                                            - Consumption 100mA @ 19V
                                            10-21-2022, 07:25 AM
                                            Lenovo 3000 Series Schematic
                                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                            3000 C100 laptop with Braille keyboard
                                            Lenovo 3000 C
                                            C100, C200 - 15-inch XGA screen
                                            Lenovo 3000 N
                                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                            N500 - 15.4 inch screen.
                                            Lenovo 3000 V
                                            V100, V200 - 12.1-inch WXGA models
                                            Lenovo 3000 G
                                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                            10-04-2024, 06:05 AM
                                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                            09-06-2024, 06:40 AM
                                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                            09-06-2024, 06:06 AM
