z50-70 nm-a273 no display
  • ous154
    • Aug 2015
    • 29
    • turkey
    hi guys i have lenovo z50-70
    mb.nm-a273
    no display en lcd but working on vga i tried everything
    if any one have any idea plz help
  • KillerFlash
    • Apr 2018
    • 8
    • Phillippines
    Re: z50-70 nm-a273 no display
    Sir, try to check your LCD cable to motherboard if their is faulty wiring and kindly double check your lcd panel if their is display but no back-light, how ever try to use other spare of lcd panel to make sure that the motherboard is working via LCD.
    • ous154
      • Aug 2015
      • 29
      • turkey
      Thanks for reply but I tried another lcd and cable it's the same
      • Ahmed ashour
        • Mar 2016
        • 12
        • Egypt
        I have the same issue
        - tried BIOS
        - another LCD and LCD cable but still gives no display
        Any help plz
        Thanks in advance
          • 20980
          Check the LCD POWER circuit in the schematic
          • Ahmed ashour
            • Mar 2016
            • 12
            • Egypt
            thanks buddy, I'll check it then give you fee back later
            • Ahmed ashour
              • Mar 2016
              • 12
              • Egypt
              I couln't fix it unfortunately, so if there is any suggestion i'd be pleasured
              and frankly i couldn't understand the LCD POWER circuit properly
              • mielta
                • Apr 2015
                • 368
                Hi
                First messure voltage at JEDP1 Pin 1,14,16,20,21,23,30 an write it here
                Pin1- ...V
                Pin14-...V
                • Ahmed ashour
                  • Mar 2016
                  • 12
                  • Egypt
                  Originally posted by mielta
                  Hi
                  Pin1- ...V
                  Pin14-...V
                  Thank you in advance for your concern buddy
                  as you requested
                  Pin 1 = 19.8 V
                  pin 14 = 0 V
                  pin 16 = 0 V
                  Pin 20 = 0 V
                  Pin 21 = 3.3 V
                  Pin 23 = 3.3 V
                  Pin 30 = 3.3 V
                  • mielta
                    • Apr 2015
                    • 368
                    Pin20 goes to +3vs the same witch goes to pin23 but on pin 20 there is an resistor R21
                    please check him
                    • Ahmed ashour
                      • Mar 2016
                      • 12
                      • Egypt
                      They don't name the resistors on Motherboard, that's why i couldn't find R21, Is there any way to find it
                      • mielta
                        • Apr 2015
                        • 368
                        follow the line from pin20 with an multimeter on Ohm
                        • Stevie2001
                          • Apr 2018
                          • 183
                          • irland
                          Try get boardview if u cant find free buy it
                          • technician37
                            • Aug 2018
                            • 30
                            • philippines
                            i almost same problem..
                            sir how if pin 21 is 0v?
                            gpu heat up but processor is not.
                            bios have 3.3v same with power switch
                            it is possible reflash BIOS?
                            thanks in advance..
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              If it has display on a VGA monitor and the GPU heats up too much while a heatsink is on the GPU, that means the GPU may be defective. So it is not a Bios issue. However, more tests are required to make sure the GPU is defective.
                              • on/off
                                • Oct 2016
                                • 333
                                • Indonesia
                                First make sure your problem NOT on LVDS cable or LED panel.
                                Connect your mobo with external monitor and display have working with it.
                                Pin 21 of LVDS conn doesn't appear:
                                DMC_DATA and DMC_CLK doesn't get signal 3.3V
                                LVDS not connect
                                Signal PCH_ENVDD not going HIGH.
                                Test and measure with LVDS cable connected without adapter or battery:
                                On LVDS conn Pin 21 not low resistance.
                                Test and measure with adapter or battery ( adapter preferred)
                                Check signal DMC_DATA and DMC CLK have correct signal. then
                                Check PCH_ENVDD signal.
                                I think not Bios issue.
