Dell Inspiron 3521
  • azhar2006
    • Feb 2018
    • 27
    • iraq
    Dell Inspiron 3521
    Hello all
    I have a motherboard type (compal_la-9104p_r1.0) explained the problem in this picture.
    The problem in PQ101 was damaged and I replaced it with a MOSFET bearing the number (AO4407A)
    The resistors were measured and were intact.
    Thanks in advance.
  • Mazorca
    • Jan 2017
    • 463
    Re: Dell Inspiron 3521
    Your problem might lay somewhere else.
    There should not be a voltage drop thru PQ100, from 19.v to 18.0v. Measure carefully, 19.XXv and 18.XXv. Looks like you are measuring the voltage thru the internal diode, and this is a P-mosfet, no voltage drop whatsoever, and voltage drop should be around 0.7v if it's not working. Measure Vgs, again, should be higher than 25v, yours is way too low, 18v.
    • piernov
      • Jan 2016
      • 4437
      • France
      PQ100 is probably fine. Still make sure that both MOSFET (PQ100 and PQ101) are not shorted.
      The issue is with the gate voltage on both MOSFET (gates are tied together). It should be lower than 18V for PQ101 to let the current flow. (they are P-channel MOSFET)
      You have to check ACOFF (on PR133) and ACIN (on PR139 or PU100 pin 13) signal.
      • azhar2006
        • Feb 2018
        • 27
        • iraq
        Happy evening to everyone
        Thank you so much
        Yes, there is a decrease in the voltage from the other side from 19 volts to 18 volts on the PQ100, while the PU100 is originally not found on the motherboard, it has been removed from the mother motherboard because it is damaged and the presence of high temperature in it.
        Where are the PR133 and PR139 resistance ?
        • piernov
          • Jan 2016
          • 4437
          • France
          Nevermind, this one is not labelled on the board…
          Instead of PR133 and PR139 you could measure all pins of PQ109.
          However, PU100 is needed for the board to turn on. You need to replaced it first.
          • Mazorca
            • Jan 2017
            • 463
            piernov: " It should be lower than 18V for PQ101 to let the current flow"
            I stand corrected, sorry for the wrong advice. Lower for P, higher for N.
            • azhar2006
              • Feb 2018
              • 27
              • iraq
              Thank You So Much Dear Mazorca
              But do not get less than 18 volts on the gate PQ101
              Is not ISL88731C the reason for it? Or is there a problem elsewhere?
              • Mazorca
                • Jan 2017
                • 463
                My knowledge doesn't extend that much. Like piernov said, measure all pins on pq109, and if you have a bench power supply, (advice: get one), test if PU100 is getting hot, internal shortage.
                • azhar2006
                  • Feb 2018
                  • 27
                  • iraq
                  OK Mazorca and piernov
                  I found something when I removed PQ101 from the motherboard got the following voltages on the PQ100, the ideal voltages (1, 2 ,3), 19 volts, and get 7 volts on pin 4.
                  I think that (AO4407) is not equivalent to MOSFET (AO4409)
                  This is the equivalent
                  • Mazorca
                    • Jan 2017
                    • 463
                    All I could tell is that AO4407 is rated for 12A and AO4409 is for 15A. Replace with equivalent or higher. Test first for shorts or open. Voltage at gate at pin4 PQ100 looks correct, should be same at pin 4 pq101, they are connected.
                    • piernov
                      • Jan 2016
                      • 4437
                      • France
                      Indeed the MOSFET should be replaced with one with the correct rating. But this is not your problem if the replacement MOSFET is not shorted and is oriented correctly.
                      You need to replace ISL88731C first before trying anything else.
                      • azhar2006
                        • Feb 2018
                        • 27
                        • iraq
                        Yes piernov I have replaced ISL88731C Was it the reason?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Dear Azhar2006, was you able to fix this?? i'm having same issue
                            DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                            This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            09-12-2024, 03:36 PM
                            DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                            This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            09-12-2024, 03:30 PM
                            09-12-2024, 03:28 PM
                            DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                            DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                            This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
