Toshiba C650M (PSC2EC-00M001) wont't power on or charge. How do I troubleshoot?
  • obes
    • Apr 2018
    • 6
    The AC adapter is good, it spits out 19.15V when plugged in (checked at the connector that goes from the jack to the motherboard, so the connector and its cable are good)
    The fuses marked F6000 and F6100 are good too, 19V on both sides from ground, and continuity is ok across them.
    CR2032 battery reads 3.10V
    Unfortunately I am not that knowledgeable about electronics and that's about all I know to check. There are several pads exposed around the motherboard which I assume are for testing but I can't find a reference as to what readings are expected on them.
    Symptoms are: when AC plugged in, not powering on at all (not even responding to button presses, not starting the fan up), and no lights at all (no AC or battery charging lights). Tried with and without the battery plugged in.
    Any idea?
  • JaroTech
    • Mar 2015
    • 351
    Re: Toshiba C650M (PSC2EC-00M001) wont't power on or charge. How do I troubleshoot?
    Hi, to know which motherboard you have, what is the number of the U6000 chip?
    • obes
      • Apr 2018
      • 6
      I hope I have the right one, but the U6000 marking doesn't have any chip right next to it. This one is a bit to the left of the marking, and it's very small:
      BQ725
      TI 12K
      A703
      • JaroTech
        • Mar 2015
        • 351
        Ok, you have the BQ24725 for the charging chip, if you can, measure all the voltages for the 20 pins of this chip. Like pin1 =?V, pin2 =?V and so on.
        • obes
          • Apr 2018
          • 6
          Alright, here goes:
          Code:
          (measured without the battery plugged in, and with AC plugged in)
           1: 6.80V
           2: between 7.95 and 8.02V
           3: 6.00 to 6.80V, unstable
           4: 7.97V
           5: 0.03V
           6: 2.65V
           7: 0.00V
           8: went from 0.10V to 0.00V while measuring
           9: 0.04V
          10: 0.00V
          11: 1.07V
          12: 1.05V
          13: 1.05V
          14: 0.00V
          15: 0.00V
          16: 6.03V
          17: 5.86V
          18: 1.05V
          19: 1.05V
          20: 18.87V
          • piernov
            • Jan 2016
            • 4435
            • France
            Disconnect the battery while troubleshooting the motherboard.
            Check for a short to ground on the B+ line. With the info we have, the easiest way is to give the resistance measurement between pin 1 (ACN) of the bq24725 and ground.
            Also check the resistance between pin 1 (ACN) and pin 2 (ACP) of the bq24725. This is connected to the current sense resistor. It should be very close to 0ohm.
            • obes
              • Apr 2018
              • 6
              With AC and Battery disconnected:
              Resistance between 1 and ground isn't stable at first but eventually settles at 71.2k Ohms
              Resistance between 1 and 2 is about 1.5 Ohm (if I can trust my cheap multimeter to be that accurate)
              Not sure which pins are +, -, and ground on the battery connector so didn't measure that.
              • obes
                • Apr 2018
                • 6
                I appreciate your help, any thoughts on the latest measurements?
                How can I tell if the voltages I got from the TI chip are within spec or not?
                  09-06-2024, 05:27 AM
                  09-06-2024, 05:59 AM
                  09-06-2024, 05:33 AM
