Can you guys help me with my Laptop HP 17 model Quanta DA063MB6F1 wich wont turn on ac adapter pluged in (AC LED off ) but work fine with battery.
after many hours trying to figure out the problem, i ended up finding that the voltage on ACDET is oscillating between 1.6v and 2.6v
PU5 BQ24738 need at least 2.4v on ACDET to work , so i tried to inject this voltage with power supply , in this case , the AC LED turned on , and i was able to start up the motherboard .
i checked the voltage devider around ACDET is OK .
resistence to ground of ACDET is ok ( i find the same value comparing to a working motherboard )
i have changed PU5 , the same problem .
I hope some body can find the solution .
thank you by advance
