PCH Problem
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
    PCH Problem
    Hi friends help me.... I have some laptops. Acer LA-7912P *2 And one Toshiba C850. There were problems some power on NO display, Some NO power. I re flowed PCH. Then Above three Laptops started to working well. But in few days again same problem. Then I replaced PCH (SLJ8C and SJTNV). Then worked well but in few days came back. I cant think where is the problem. Help......... any idea. Thanks....
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: PCH Problem
    c850 its gpu issue , probably , unless its uma
    • pcnetch
      • Aug 2013
      • 125
      • Sri Lanka
      Re: PCH Problem
      It is no GPU chip. Intel vga.
      • dmartins
        David M
        • Apr 2014
        • 197
        • Lisbon
        Re: PCH Problem
        I have an similar C850, with intel VGA and no image
        Did you fix it ?
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          Re: PCH Problem
          replace PCH
          • pcnetch
            • Aug 2013
            • 125
            • Sri Lanka
            Re: PCH Problem
            Thanks for all replies
            • banchi99
              • Jul 2015
              • 107
              • U.S.A
              Re: PCH Problem
              Bios problem. reprogram it..
              • pcnetch
                • Aug 2013
                • 125
                • Sri Lanka
                Re: PCH Problem
                No anyone faced like this problem. I reprogrammed bios, Replaced PCH Could not solve the fault. Want to know my problem or replaced PCH problem. Can't think. Now already I have about 10 laptops after pch re flowing working few days then no display. power on no diplay
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
                • SDNarcia
                  Dell 15R-5521 keyboard problem (KBC?)
                  by SDNarcia
                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                  As additional information,...
                  07-20-2024, 10:47 PM
