Asus K43sv- Display?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Hello to all Badcapsian...
    i'm here again to ask a help about my Asus K43SV
    Main Problem No Display
    No.1 No Display
    No.2 Automatic turn on if i plug the Adapter (Supply)
    i do the following.
    1. Cleaning mobo, ram (3 Brands i test but 2 of them is 100% working)
    2. Change Adapter (supply)
    Also I test The LED to Working Unit as a same compatible type ( LED Working)
    but i avoid Reheating the VGA Chip
    i need your Solution... TIA
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Re: Asus K43sv- Display?
    Updating......
    I look at the the board they have corroded @ ITE Chip as know IO Chip
    - i try to re soldering the pin and trace no open circuit.
    question in is a Culprit on the system board. or if i have a same chip available and i Change it(replace As Same type). can do anything example: Update bios...
    Need Advice Please...
    How can i Do?
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      Follow up.....
      • mcoytzhi27
        Mr
        • Nov 2015
        • 43
        • philippines
        No.1 No Display
        i do the following.
        flash bios
        • mehar
          • Feb 2015
          • 12
          flashing bios is the best option
          • raizenn27
            • Jun 2011
            • 95
            • philippines
            Hello there friends..,i also have same problem and i did try to flash bios but same outcome..is there any solution available out there?? Or some one have a schematic for this board..thanks
            • Febri alfio
              • 14
              • Indinesia
              I also have same problem, k43sv rev 3.0,no display, but capslock usb keyboard normal
              • vhn1998
                • Jun 2015
                • 56
                • Vietnam
                check 3v LCD
                • balobi
                  • Jan 2015
                  • 88
                  • phillippines
                  i have same issue. i check voltage on lvds section i 19v present but no 3.3v. i need schematic ot someone solve this kind of issue.
                  • balobi
                    • Jan 2015
                    • 88
                    • phillippines
                    Originally posted by vhn1998
                    check 3v LCD
                    did you solve the problem?
                    • ronelex
                      • Oct 2016
                      • 195
                      • Philippines
                      I also have this problem, with usb keyboard function, missing LED_BKLTEN and +3VS_LCD,
                      I tried to convert it to UMA by removing +VGA_VCORE coil and LED_BKLTEN and +3VS_LCD reads 3.3v but still no display
                      • emestee
                        • Dec 2019
                        • 228
                        • Bulgaria
                        Since you have corrosion on the board, you need to examine both sides of the board very carefully for additional liquid damage. Do not power up the board until you've cleaned it and replaced the corroded components.
                        Bear in mind that liquid and corrosion can get under big chips, and this is especially relevant for BGA ones.
                        After this do the standard diagnostics: RTC battery voltage, coil resistances, S5 voltage and current draw before proceeding further.
                        Please follow the methodology and do not attempt to guess solutions.
