acer d270 3v_alws become 6.70v
  • HarryPK
    • Mar 2014
    • 210
    • barabai
    Re: acer d270 3v_alws become 6.70v
    how to check i/o. ihave changed with new one....
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      hey having 3.3 on powerbutton and nothing to do ..
      you can have 3.3 volts only feeded by REG3 LDO whatsoever you can call them .
      now if you got 6 volts on tha rail of 3.3 ..then first chek the main regulator (like ktm told you , replace all fets on the 3.3 volts , and therefore you main regulator is not ok .. who feed the voltage is the regulator , if you are having 6 volts then regulator is dead .. now attention the schematic you might have can be a lower or upper release , not having certain components on board , don't mean they were reaped off , they might be off due to the release of the board.
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        another thing , start cheking main QFN for leaks , chek on resistance mode to ground on the 3.3 line , you will find something more damaged for sure
        • HarryPK
          • Mar 2014
          • 210
          • barabai
          Originally posted by ktmmotocross
          i am not amazing about that. 3,3v have many ics and with your 6,7V many of them goes to hell
          you are right., many of 3.3 v ic were damage ... do you have any sugestion what ic have to check first? i am new be please give me an advice.....
          • HarryPK
            • Mar 2014
            • 210
            • barabai
            i found short cap around ec... stlill searching...
