  • ekozeko333
    • Jun 2025
    • 6
    • Austria
    🧠 What I’ve Done So Far
    Flashed a known-good 16MB "virgin" BIOS (W25Q128JW_1.8V) including DMI regions
    Verified BIOS and EC flash using CH341A (1.8V adapter, verified writes/reads)
    Power rails seem fine; fan and keyboard LED briefly respond
    Still no PD negotiation to 9V/15V/19V, and board does not POST
    ⚠️ Critical Finding – Empty PD SPI Flash
    I found a second SPI flash chip:
    W25Q80DVN1G (1MB, 3.3V)
    Located near USB-C ports and HDMI
    Connected to TPS65988 USB-C PD controller (as confirmed in schematic, see attached)
    💥 I dumped this chip and it is completely empty – all bytes are FF!
    I re-read it multiple times to be sure.
    ❓My Questions
    Why would the PD flash chip (25Q80DV) be totally blank?
    Can ESD or a PD overcurrent event cause this?
    Could a bad BIOS flash or TPS failure erase it?
    Is the TPS65988 dead if it can't boot from SPI?
    Or can it be recovered by flashing the correct firmware to this chip?
    Where can I get a known-good dump (1MB) for this flash?
    Is this blank PD firmware the root cause of stuck 5V PD and no power-up?
    🧾 Summary
    BIOS/EC verified, flashed, still no boot
    TPS65988 likely cannot initialize — its SPI flash is blank
    USB-C stuck at 5V, no 19V negotiation, no battery charging
    Board behavior points to missing PD controller firmware/config
    Need help locating valid firmware or confirming recovery method
    Thanks to everyone in advance for guidance or sharing working dumps. 🙏
    • 20361
    You can request the PD firmware in the bios requests sub forum. You can try one thats posted for a different model and see what happens - https://www.badcaps.net/forum/troubl...34#post1511939
    • Ponto da Manutenção
      • May 2024
      • 58
      • Brasil
      I need more detailed information about your case.
      Equipment serial number?
      Original BIOS backup?
      I didn't quite understand, did you write or record the (EC IT5570VG)?
      I'm posting a (Firmware - ThinkPad USB-C Dock Gen 2 40AS).​​
      • ekozeko333
        • Jun 2025
        • 6
        • Austria
        Model name: 82A2
        Factory ID: CS20
        S/N: LR0E6ZCM
        neither EC IT5570VG I didnt touch it. record or wrote... The initial text was a bit missleading with the EC. I didnt rewrite the EC only the bios and only read the SPI FLASH W25Q80DVSSIG--> it was empty.
        what happened exactly? did the esd wipe out the memory?
          • May 2024
          • 58
          • Brasil
          I do not recommend this recorder model (CH341A)...it is not reliable..
          Here is your repaired file.
          • ekozeko333
            • Jun 2025
            • 6
            • Austria
            I suspect that I cannot write anything to the pd flash (25Q80DV).. it appears to be dead. Likely from the esd damage?
            I tried SPI with Asprogrammer using ch341A.
            Whats much better then the CH341A?
              • May 2024
              • 58
              • Brasil
              I have 4 recorder models, but I recommend these two.
              XGecu T76 USB3.0
              Svod 4
              • ekozeko333
                • Jun 2025
                • 6
                • Austria
                A little update.
                the 25Q80DV is DEAD.
                Ive ordered a new one, comes this saturday.
                Will try to solder a empty 25Q80DV to the board and let the bios flash it on BOOT TIME. I might get lucky. IF not, then I will need someone to provide me with a working dump from the 25Q80DV.
                Wish me luck, will report back.
                  • May 2024
                  • 58
                  • Brasil
                  Originally posted by ekozeko333
                  A little update.
                  I posted the file for you to record on (25Q80DV)...
                  • ekozeko333
                    • Jun 2025
                    • 6
                    • Austria
                    The original content size is 1024 for the 25Q80DV ???
                    Panamera_fw_duce2_Ver5_07_007.bin ---> 512kb ?
                    do I flash it from 0x00000000 the 512kb? thats ok?
                      • May 2024
                      • 58
                      • Brasil
                      How do you know for sure that the file is 1mb if it was blank?
                      The file I posted is from the manufacturer Lenovo.
                      "Why would the PD flash chip (25Q80DV) be totally blank?"
                        SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                        This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                        09-12-2024, 03:30 PM
                        SHUTTLE XPC slim DH110 XPC slim i3-7300 Specification for Upgrade or Repair
                        This specification for the SHUTTLE XPC slim DH110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110 boardview and XPC slim DH110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                        09-12-2024, 03:28 PM
                        HP Slim Desktop S01-aF0009nf Slim Desktop J5005 Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-aF0009nf can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0009nf boardview and Slim Desktop S01-aF0009nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
