Dell Inspiron 6400 can't turn on
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Dell Inspiron 6400 can't turn on
    giant and steve,
    if first fet tested good off board, then its much better to remove it and feed (4 v low 1 amp increasing gradually) after the fet. bypassing the fet will shorten your troubleshooting time.
    note: be very careful in doing this technique in other sections. you might destroy other components that are good by mistakenly applying over voltage.
    please post correct schematic
    thanks
    • gianttora
      • May 2014
      • 17
      • Malaysia
      Originally posted by fddizon
      giant and steve,
      thanks
      Yes i alredy tested it off board and the fet is still in good condition.
      Here is the schematic
      I refer to page 45.
      May i know how to feed voltage after the fet ? Any reference of video which i can refer to?
      • SteveHart
        • Mar 2012
        • 11
        • Indonesia
        giant and steve,
        thanks
        Good point Fddizon, thanks for your input. Yes it would be safer to do that. Surely enough when injecting voltage to the other rails it should not exceed the voltage the rails designed to be. Have done a couple or more unnecessary damage by that stupidity myself.
        • SteveHart
          • Mar 2012
          • 11
          • Indonesia
          I refer to page 45.
          Assuming the FET is now off board , feed the voltage after the FET. In the schematic it is marked as DC_IN+. Apply the voltage to the drain (pads) of PQ6. Read fddizon post earlier
          • Ramee
            • Jul 2014
            • 218
            • Israel
            here
            • gianttora
              • May 2014
              • 17
              • Malaysia
              #26
              I'm not sure whether i feed the voltage in a right way. I put black probe to the screw hole for grounding and red probe at the PC140 since you suggest to feed the voltage after the FET (PQ6). I'm doing this while PQ6 is off the board.
              When i fed the voltage, regulated power supply showing the was a short occured and FET (PQ42) became so hot. So is it PQ42 is the culprit?
              One more thing is my friend told me, if I want to replace faulty FET i just need to follow the last number from the FET code number. If even number just replace with even number. If odd just replace with odd number. Is it true?
              • SteveHart
                • Mar 2012
                • 11
                • Indonesia
                #27
                As usual, check the mosfet out of the board. If it is short, it is the culprit. If it is tested ok, then you'll have to search other components the same way as you did before, only this time with the second mosfet out of the circuit.
                For the mosfet replacement, it's not always true odd number is P channel and even number is N channel mosfet. It depends on the manufacturers numbering system. And even when it's the same channel type you should consider things like voltages, ampere, Rds on characteristic of the mosfet. Better to read the datasheets first.
                • gianttora
                  • May 2014
                  • 17
                  • Malaysia
                  #28
                  OK. I already removed PQ42. I did a test and found this mosfet is OK. I fed voltage at PR132 with 4 volt. Voltage value is decreasing to 0.4v and ampere increase more than 2.00 A. So I lowered the Amp to 1. No component became hot this time.
                  • SteveHart
                    • Mar 2012
                    • 11
                    • Indonesia
                    #29
                    Search the entire board for components that become hot, not just the surrounding area of PQ42. The shorted component may be placed far from PQ42, but still connected to +PWR_SRC
                    • gianttora
                      • May 2014
                      • 17
                      • Malaysia
                      #30
                      I found northbridge chip become hot when i fed the voltage. So do i need to reflow or reball this chip?
                      • fddizon
                        • Sep 2011
                        • 555
                        • Philippines
                        #31
                        check pq39 and pq40. also PC132.
                        check resistance dc_in+ vs grnd. if shorted, test all components on this rail
                        check pc140, pc125, pc141 and pc135
                        also c578
                          DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 02:15 PM
                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                          09-12-2024, 03:44 PM
                          DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
