Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
Issue Description:
✅ Replaced thermal paste (correctly applied, heatsink is secured).
✅ Checked fan operation (spins at 5V).
✅ Updated BIOS to the latest version (including EC firmware update).
✅ Checked VRM 1V coils – extremely hot at high CPU temps.
✅ Confirmed BIOS power and cooling settings.
✅ From Dell Power Options app, I changed system power setting to COOL, no help.
I am attaching images of the screen showing CPU temp.
No visible component damage, everything looks normal.
Rather than the fan not turning on (because there is no PWM signal), I believe the main issue is the CPU's sudden and erratic temperature spikes.
Any advice or suggestions would be greatly appreciated! Thank you.
Issue Description:
- CPU Overheating to 100°C
- When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.
- When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
- However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
- I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
- Thermal paste has been replaced with fresh paste, and the heatsink is firmly attached.
- Fan PWM & TACH Signal Issues
- PWM signal stays at a solid 3V (does not switch to a square wave to start the fan turning).
- TACH signal remains at 0V, obviously fan is not turning.
- Compared with another working Dell laptop, the PWM signal should be a square wave when the fan spins, but it remains solid 3V on my faulty laptop.
- Core Thermal Throttling Triggering
- Watching CPU package temperature with HWiNFO, I can see the thermal throttling happening when temps reach high levels.
- Temporary Fix: Lowering Maximum Processor State to 90%
- When I change CPU Maximum Processor State to 90% (default is 100%) through Windows Power Options > Advanced Settings, everything returns to normal:
- No overheating
- No throttling
- VRMs do not get extremely hot
- BIOS & EC Firmware Updated
- Updated BIOS to the latest version, which included an Embedded Controller (EC) firmware update as well.
- No noticeable changes in fan behavior or temperature management after the update.
