Asus ROG Zephyrus G14 GA401QM Won´t charge
  • judamex
    Active Member
    • Jan 2021
    • 183
    • Mexico
    Hello, I have an Asus ROG Zephyrus G14 GA401QM which had a short circuit in the BQ24800 and would not turn on. The BQ24800 was replaced and now it turns on with the charger, but does not charge the battery. I have schematics and boardview, I checked mosfets and basic signals, but everything seems to be fine. The output voltage to the battery does not exceed 1V
  • mon2
    • Dec 2019
    • 14148
    Are you using the original and recommended power adapter with the proper ratings? If the adapter is underpowered, the battery will not charge and the CPU will be throttled.
    Carefully measure the voltage to ground of the following battery connections:
    P_SMB0_CLK
    P_SMB0_DAT
    Post each measurement.
    • judamex
      Active Member
      • Jan 2021
      • 183
      • Mexico
      P_SMB0_CLK
      P_SMB0_DAT
      Yes, I am using the original adapter, and I am also injecting adequate voltage, with amperage similar to that of the original adapter.
      The measurements are as follows:​
      P_SMB0_CLK = 3.3V
      P_SMB0_DAT = 3.3V
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        DC-in mosfet.pin4 voltage?
        • judamex
          Active Member
          • Jan 2021
          • 183
          • Mexico
          the voltage on pin 4 of mosfet DC-in is =25V
          voltage for high Mosfet on Bat+ =0.9V
          I measured all the mosfets to check for short circuit and they are fine.​
          • mon2
            • Dec 2019
            • 14148
            DCin mosfet gate voltage is fine to enable the power path.
            The battery charge voltage will be defined by the high side mosfet @ PQH8901 and the low side mosfet @ PQL8901.
            Remove all power. Measure the resistance across the high side mosfet @ PQH8901.
            Measure:
            source / drain
            source / gate
            gate / drain
            Post each measurement. Repeat for PQL8901.
            The ~19v adapter voltage travels onto the main power rail -> then these 2 mosfets are used to switch on / off to dial down the voltage for the battery to charge by the charger IC.
            Also interested in the voltage to ground on pin # 1 and # 2 on the charger IC.
            • judamex
              Active Member
              • Jan 2021
              • 183
              • Mexico
              Measure:
              source / drain
              source / gate
              gate / drain
              PQH8901
              Source (Red) / Drain (Black) = 0.65 Mohm
              Source(Black) / Drain (Red) = 0.7 Mohm
              Source (Red) / Gate (Black) = 180Kohm
              Source (Black) / Gate (Red) = 180Kohm
              Gate (Red) / Drain (Black) = 700Mohm
              Gate (Black) / Drain (Red) = 0.82Mohm
              PQL8901
              Source (Red) / Drain (Black) = 0.600Mohm
              Source(Black) / Drain (Red) = 0.700Mohm
              Source (Red) / Gate (Black) = 8.3Kohm
              Source (Black) / Gate (Red) = 113Kohm
              Gate (Red) / Drain (Black) = 0.750Mohm
              Gate (Black) / Drain (Red) = 0.850Mohm​
              Pin 1=20V
              Pin 2=20V
              • mon2
                • Dec 2019
                • 14148
                Flux and remove PQL8901​. This mosfet has low resistance. Then measure it again when it is out of circuit on your desk. Do not power up without this mosfet. Very likely this mosfet is defective. The high side may also be bad with the 180k ohms but for now, suggest to replace the low side mosfet.
                • judamex
                  Active Member
                  • Jan 2021
                  • 183
                  • Mexico
                  Flux and remove PQL8901. This mosfet has low resistance. Then measure it again when it is out of circuit on your desk. Do not power up without this mosfet. Very likely this mosfet is defective. The high side may also be bad with the 180k ohms but for now, suggest to replace the low side mosfet.
                  I measured the mosfets from the outside, and they have normal values, there is no low resistance, nor short circuit.
                  The measurements between source and gate, remain low on the motherboard, for both mosfets​
                  • mon2
                    • Dec 2019
                    • 14148
                    Test with another known good battery. Try Amazon. You can always return the battery if it is not required. It is possible that the battery is locked and this condition is reported to the charger IC over the SMBUS. For the same reason, the battery voltage is kept low.
                    • judamex
                      Active Member
                      • Jan 2021
                      • 183
                      • Mexico
                      The strange thing is that the battery worked until it died, and that's when they decided to repair it because the charging LED no longer lit up. But I'll see if I can try another battery that I know works well.
                      • judamex
                        Active Member
                        • Jan 2021
                        • 183
                        • Mexico
                        I ordered another battery from Amazon, put it in and it showed the same problem:
                        -battery LED blinks
                        -same voltages as I mentioned
                        -battery in windows shows 100% charge (obviously when disconnecting the charger it turns off by itself)
                        -the laptop turns on by itself
                        I should order a brand new BQ2400 from Aliexpress​
                        • judamex
                          Active Member
                          • Jan 2021
                          • 183
                          • Mexico
                          Update:
                          After ordering the new bq24800 from aliexpress, it is still in the same conditions
                          -battery LED blinks
                          Anything else I can measure for these cases?
                          • Deby
                            • Aug 2015
                            • 52
                            • Serbia
                            I had the exact same problem.
                            All 5 mosfets are working.
                            I changed the BQ24800.
                            And the problem remained the same.
                            Then I looked at the schematic and noticed that Asus uses a similar principle with the smart pin as Dell, HP and Lenovo.
                            The motherboard communicates with the charger through the DC connector (smart pin).
                            For HP and Lenovo we know we can trick it with resistors.
                            I don't know about Asus.
                            But it was enough for me to know that my charger is not good, when I plugged in a 120W USB-C charger (from my Xiaomi phone) and the battery charging started.
                            It draws about 500mA and charges the battery on a switched off laptop, but it's enough of a sign for me that everything is fine and I need the original 180W charger.
                            Maybe you have the same problem.​
                            • mon2
                              • Dec 2019
                              • 14148
                              The op is using the original OEM power adapter.
                              If the battery is disconnected, does windows report the battery is missing? Does the bios have a battery detection feature?
                              Carefully measure the voltage to ground of each pin on the charger IC and post here with the pin number, pin function and measured voltage. Attach the battery and adapter.
                                ASUS ROG GA401QM-K2068T Notebook Zephyrus G14 Specification for Upgrade or Repair
                                This specification for the ASUS ROG GA401QM-K2068T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-K2068T boardview and GA401QM-K2068T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 03:10 AM
                                ASUS ROG GA401QM-K2065T Notebook Zephyrus G14 Specification for Upgrade or Repair
                                This specification for the ASUS ROG GA401QM-K2065T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-K2065T boardview and GA401QM-K2065T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                ASUS ROG GA401QM-HZ279 Notebook Zephyrus G14 Specification for Upgrade or Repair
                                This specification for the ASUS ROG GA401QM-HZ279 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-HZ279 boardview and GA401QM-HZ279 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 02:50 AM
                                ASUS ROG GA401QM-K2196T Notebook Zephyrus G14 Specification for Upgrade or Repair
                                This specification for the ASUS ROG GA401QM-K2196T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-K2196T boardview and GA401QM-K2196T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                ASUS ROG GA401QM-HZ212T Notebook Zephyrus G14 Specification for Upgrade or Repair
                                This specification for the ASUS ROG GA401QM-HZ212T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA401QM-HZ212T boardview and GA401QM-HZ212T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 01:00 AM
