ASUS GL504G no power
  • coconoce
    • Jan 2025
    • 9
    • ITALY
    ​Hello, I acquired a not working ASUS ROG SCAR GL504G (i7 8750H-RTX 2070 8gb GL504GW rev 4.1) to try to try to repair it and learn something new.
    The laptop didn't want to turn on, while testing removing components it turned on for a couple of seconds but after that no more signs of life. I cleaned and inspected the board and found some tiny solder spheres rolling around, maybe signs that someone already tried to work on it. The other thing i found was a pair of stripped solder joints where there should have been what from the images I found online I think is a fuse, I am now trying to find its specifics.
    I know the starting point is not one of the best but I still would like to give it a try
    To troubleshoot I started following the main power rali, the 20V line seems fine around the board but the 3.3V and 5V coils i checked are completely dead. I marked down on the picture the voltages measured from what I thought to be the key points but i am now at an empasse
Name:	voltage front.jpg
    how can I go on to try and troubleshoots the missing lines?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    The ripped solder joint you are referring to seems like a capacitor.
    Link the schematic/boardview
    Start by measuring resistance to GND on all coils(black probe to GND and red probe on each coil)
    For measuring resistance to GND on cpu/gpu/pch coil, set the meter to 200 ohms scale and for others you can set it to 20K.
    Post the measurements here.
    • coconoce
      • Jan 2025
      • 9
      • ITALY
      thanks for the reply, I'm looking around for the schematic of this particular revision, for now i found only older or newer models
      here's the values, how come the reading takes a while? is if because of the capacitors in the circuit?
      cpu's coils read were all between 2 and 0.2 ohm
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        2 ohms on cpu coil is fine but specify which coil shows 0.2 ohms as this low resistance is a cause of concern.
        • coconoce
          • Jan 2025
          • 9
          • ITALY
          yesterday I must have fumbled while taking the measurements, today I took the time to take the measurements and the result is that all the cpu's coils read 2ohm while all the gpu's coils look shorted.
          Next step would be to remove all the coils to locate the short right?
          • piernov
            • Jan 2016
            • 4436
            • France
            https://www.badcaps.net/forum/troubl...61#post1459061
            2.2. Don't suspect that something is shorted with no reason
            Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
            • coconoce
              • Jan 2025
              • 9
              • ITALY
              you're right sorry, in the hurry of the moment I didn't consider what i read. I'm in the first steps of learning
                ASUS ROG GL504GW-ES019T Notebook Strix Specification for Upgrade or Repair
                This specification for the ASUS ROG GL504GW-ES019T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GW-ES019T boardview and GL504GW-ES019T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 09:32 AM
                ASUS ROG GL504GW-ES043 Notebook Strix Specification for Upgrade or Repair
                This specification for the ASUS ROG GL504GW-ES043 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GW-ES043 boardview and GL504GW-ES043 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 09:17 AM
                ASUS ROG GL504GW-ES035T Notebook Strix Specification for Upgrade or Repair
                This specification for the ASUS ROG GL504GW-ES035T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GW-ES035T boardview and GL504GW-ES035T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 09:06 AM
                ASUS ROG GL504GW-DS74 Notebook Strix Specification for Upgrade or Repair
                This specification for the ASUS ROG GL504GW-DS74 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GW-DS74 boardview and GL504GW-DS74 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                09-06-2024, 07:58 AM
                ASUS ROG GL504GW-ES043T Notebook Strix Specification for Upgrade or Repair
                This specification for the ASUS ROG GL504GW-ES043T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL504GW-ES043T boardview and GL504GW-ES043T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 07:46 AM
