have dell la-f381p no power on adapter working fine with battery but not charging.first mosfet pq9 has 18v on gate.+3.3V_VDD_DCIN is missing and i have 1.6 v on pin 3 of lm393 and no voltage on all the pins.cant find schematics with same board no but have attached similiar schematic https://www.badcaps.net/filedata/fetch?id=2083398. any help is appreciated thanks
dell ddm90 la-f381p no power on adapter
Thanks for the reply mon2 but the laptop is not powering on with the adapter without battery and 19v does not pass through the first MOSFET I have changed the charging ic 88739a.the pq9 is p channel MOSFET if i am not wrong but I get 18v on the gate .Comment
If you have such a high voltage on the gate, then the P-channel mosfet will remain disabled. Only if the P-channel gate is lower than the voltage on the source / gate pins will the mosfet enable. Having said this, suspecting one of the DCin mosfets is leaking (as per the article by piernov on charging circuits - see above sticky).
Remove all power. Meter in resistance mode.
Measure the resistance across the mosfet:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)
Post each measurement. We are checking if the resistance is low, then the mosfet is defective. Each resistance check should be hundreds of k ohms or higher.
Repeat for the 1st DCin mosfet as well.Comment
No point troubleshooting PS_ID at this stage as it cant work without the pull up 3V which will be generated only when 19V reaches CLR.
Focus should be on gate voltage of dc-in fets.Comment
This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 06:00 PM
This specification for the HP ProBook 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 12:00 PM
This specification for the HP EliteBook 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 12:00 PM
- Loading...
