Re: dell n5110 no charger detect
H ABBAS GOVANI YOU ARE RIGHT AT YOUR POINT
your charge is also ok and battery is also ok
your problem in charge detection circuit,
in dell laptop and charger there is third pin in adapter, which should work and this send a data to laptop through adaptor third pin that this is a genuine and matching rating adapter. if this signal not goes to laptop the adapter show in laptop but not charging, if you check the battery status in laptop this will show "adapter connected, but not charging"
it is belong to the center pin of your charger , trace the circuit of adapter power socket center pin circuit,
pl check PQ4004 AND PQ4003 AT ICREF PIN AT PU4001 (BQ24745)
i was facing this problem two times same as water spell NR adapter socket,
again you are right adapter connected but not charging this is common problem with dell laptops, these laptop not working with local or other adapter these working with there own adaptor and with same power rating like 65w and 95w
