Charging issue..
  • ashiq
    • Dec 2020
    • 20
    • india
    Charging issue..
    DABKXDMB8F0 , motherboard the battery voltage is fluctuating like 8.66, 8.55,8.7V
    The charging ic is BQ24780s,
    Without battery connected also there is 8v in the battery connector is it normal ?
    the SDA and SCL also fluctuating without battery connected also ..
  • mon2
    • 14659
    SMBUS lines will toggle and fluctuate as the traffic is placed on these lines. Does the motherboard power up normally and boot to the operating system? In Windows, is the battery detected?
    • ashiq
      • Dec 2020
      • 20
      • india
      the system will on and off suddenly.
      • ashiq
        • Dec 2020
        • 20
        • india
        the 8v comming without battery is it normal?
        • mon2
          • 14659
          That battery charge voltage will enable if pin #15 (BATPRES# is logic low = 0V). If this pin #15 = logic high then the battery charge voltage will disable.
          Sometimes, the logic board designers will hardwire pin #15 to ground. Confirm what you have onboard.
          Review the charger ic datasheet on the operation details.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Simone Vergani
            Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
            by Simone Vergani
            I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
            To assist with troubleshooting, I'm attaching two power circuit schematics:
            • Power
            03-05-2025, 02:25 PM
          • drlarsen
            MacBook Air M1 A2337 battery/charging issue
            by drlarsen
            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
            After some hours, the battery status did not improve. Restore via DFU did not help.
            I connected the power adapter to a Kill-a-Watt...
            07-17-2025, 02:35 PM
          • Julian Bailey
            HP ProBook 445 G8 Battery not charging
            by Julian Bailey
            Hi all
            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
            I have gone around the board with a MM and cant find anything
            Windows shows the battery fine,...
            10-11-2024, 10:34 AM
          • code share
            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
            by code share
            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
            Here's what I've tried so far:
            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
            • Booted successfully on AC power only with the battery disconnected
            • Visual inspection of the battery — no swelling, burn marks, or connector damage
            • Battery
            04-21-2025, 12:50 PM
