Just wondering if anybody knows anything about a problem which allows the A2141 to charge but not power up?
A2141 20V and charging 2.8A but no powerup
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by ThomasraudHello,
i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
QUOTED
-It works on charger (without battery connected-only charger)
-It works on battery (without charger connected-only battery)
-& it also works when plugged in battery & charger, but it's not charging the battery
//Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
and..
QUOTE
The IC cannot maintain the input current level... -
by Schluchti45Hello,
i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead. -
by ScoffLooking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection... -
by SluggerBI have two TCL A30 phones.
Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
New Phone: Works fine, bought as a donor board to try and repair Old Phone
My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone.... - Loading...
