Elitebook 840 G5 CPU Stuck on 0.40 GHz
  • medinfo
    • May 2016
    • 328
    • Morocco
    HP Elitebook 840 G5, CPU Stuck on 0.40 GHz, this problem can be fixed by (ThrottleStop) by disabling (BD PROCHOT), but i need to fix this problem.
    -Charger original, same voltage and watts
    -Battery original good health
    -Windows Clean install
    -Changed all parts, ssd, ram ....
  • mon2
    • Dec 2019
    • 14050
    Perhaps same voltage and watts but it is the adapter ID analog voltage (HP models only) that is read by the EC that matters and defines what the logic board will support. If the ID voltage is too low, the cpu will throttle and halt charging etc. Review the center pin voltage of this adapter at the dcin connector contact. Compare this voltage to other working HP laptops.
    This safe and lower voltage is sampled by the A/D converter in the EC to gauge the power of the adapter. There are public articles on this topic.
    • medinfo
      • May 2016
      • 328
      • Morocco
      i know this errors from the charger, but i tested with others chargers, type c charger same problem
      • medinfo
        • May 2016
        • 328
        • Morocco
        and same problem without charger only battery
        • mon2
          • Dec 2019
          • 14050
          If you use Type C power adapter -> what is the voltage and current draw showing on the type C meter? Is the cable between the adapter and this laptop supplied with the power adapter (captive cable and is not removable) or did you attach this extra type C cabling? The details of the type C cable is important. For proper support, the type C cable should be an active cable and rated for 100W (or higher). Only then will you have the E-marker chip inside the cable head and the gauge of the wires inside the cable will be beefy enough to support higher currents. If the cable is NOT e-marked, then you will throttle even the type C adapter and this will throttle the logic board speed and features.
          BTW - Can you link or post a schematic? Only inside the schematic forum. My (paid sub) database does not appear to offer this schematic.
          • medinfo
            • May 2016
            • 328
            • Morocco
            i tested with a lots of original charger, 65w type-c cable not removal, hp blue with same voltage and amp, and without charger only battery powerd same problem
            • mon2
              • Dec 2019
              • 14050
              Any schematics?
              Locate the charger IC. Is it the BQ24780S?
              • medinfo
                • May 2016
                • 328
                • Morocco
                Any schematics?
                Click image for larger version  Name:	prochot.png Views:	0 Size:	195.9 KB ID:	3319435
                Charger iC Schematic
                From @abdoelhosseiny@aol.​
                • mon2
                  • Dec 2019
                  • 14050
                  Measure the voltage to ground of pin # 23 on this charger IC.
                  • medinfo
                    • May 2016
                    • 328
                    • Morocco
                    3.97V
                    • mon2
                      • Dec 2019
                      • 14050
                      So this throttle action is NOT from this charger IC. When does this board 'slow down'? Is it after the logic board is mounted inside of an enclosure? There is a thread on this forum where there was a shorting during the clamshell assembly and this led to the logic board being throttled.
                      • medinfo
                        • May 2016
                        • 328
                        • Morocco
                        both, motherboard mounted or unmounted, but i noticed an abnormal overheat in the ec controller (NUVOTON) when charger or battery is connected.
                        • mon2
                          • Dec 2019
                          • 14050
                          Study the adapter ID pin which should be a safe voltage created by resistor based voltage dividers. What is the voltage on this pin when the adapter is connected? If it is too high, this could be an issue. This voltage is sampled by an A/D converter on the EC to determine the power adapter rating.
                          • medinfo
                            • May 2016
                            • 328
                            • Morocco
                            the voltage in the charger before it's 19.80/10v, and after connected 19.77/0.463v
                            • medinfo
                              • May 2016
                              • 328
                              • Morocco
                              any idea ?
                              • mon2
                                • Dec 2019
                                • 14050
                                At this time, the CPU is being throttled. What is the voltage to ground of PROCHOT#? This is pin #23 of the charger IC you have linked earlier. This label is with a '#' suffix which means the logic line is active LOW. That is, only if this signal is LOW = ~0 volts then the CPU will be throttled due to this signal.
                                The fault may be elsewhere since this signal is ~3v97 = logic high.
                                Does the ThrottleStop software work for you? When you run this software, what is the voltage to ground of PROCHOT#?
                                • flat-earther
                                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                                  by flat-earther
                                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                  Windows also shows ''Plugged in'' when charger is not connected.
                                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                  If I let battery run out and say it has 3% Windows will...
                                  06-24-2025, 09:32 AM
                                  HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 05:50 AM
                                  HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 05:20 AM
