Lenovo Yoga 500-15ISK several faults
  • s_henya
    • Jan 2011
    • 480
    • Israel
    Hi guys,
    Anyone ever worked on this board before?
    Few issues im trying to resolve:
    1. Laptop will not power up without main battery connected (missing 3.3v line)- measuring on the 3.3v coil i can see 0v but for split second it jumps to 3.3v and drops again.
    Is this laptop supposed to power on only with battery connected?
    2. Battery voltage + line is getting 19v, for my experience 7.4v battery isn't meant to be charged with main line voltage- is this normal?
    3. No display on laptop screen, if i disconnect the LVDC cable and connects by HDMI everything works- possible LVDS cable\ mainboard issue\ screen connection issue.
    Any tips?
  • mon2
    • Dec 2019
    • 14183
    Every laptop should be able to power only using only the battery, provided that the battery is charged. Do review the battery charger sticky above by piernov. It is very possible that you have a leaky mosfet in the power path from the external power adapter and the main power rail (V20B+).
    Review the details below on how to test the mosfets. Do inspect and measure the mosfets that are @ PQ311 and PQ312. At least one of these may be leaky.
    Correct. Way too high of a voltage to charge the battery pack. May have caused damage to the battery pack. This is implying that the high side and/or low side battery charging mosfets are not working correctly to dial down the ~19 volts that is from the power adapter. These 2 mosfets must turn on / off together to lower the ~19 volts to a safer charge voltage.
    Remove all power. Meter in resistance mode. Measure the resistance across these mosfets to check if they are leaking.
    Measure:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement in ohms. A low resistance means the mosfets is probably leaky and should be replaced. Check the high side and also the low side mosfet.
    Click image for larger version  Name:	battery_charge_mosfets.png Views:	0 Size:	221.0 KB ID:	3279114
    • s_henya
      • Jan 2011
      • 480
      • Israel
      Dear Mon,
      Thank you for always finding time to comment and suggest solutions!
      in this case i think i was misunderstood.
      The battery is charged, laptop is able to power on and work using only battery- normal so far.
      If i disconnect the battery and power on using only power from the charger the laptop does not power on.
      Measuring on the 3.3v coil i can see 0v but for split second it jumps to 3.3v and drops again.
      Is this laptop supposed to power on only with battery connected (charger alone isn't enough)?
      ​Battery charging FETs tested good (OL between Gate to source. Gate to Drain. Source to Gate Source to Drain. Drain to Source and Drain to Gate)
      not sure how to continue....
      maybe schematics or boardview?
      • mon2
        • Dec 2019
        • 14183
        I think we are still on the same page.
        OL between...
        Switch to a higher scale on your meter until you have a resistance measurement. OL ('over limit') often means the meter scale is too low for the measurement. The schematics are locked to my paid subscription and so far, unable to crack the lock mechanism. Will check on the bv files and their state.
        • s_henya
          • Jan 2011
          • 480
          • Israel
          For mosfet resistance test i usually use diode mode for voltage drop, think it would be more useful.
          will check and reply back.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I confirm that this board works only in adapter also. However, seen a couple of boards where laptop dont powers on without a battery(Dell).
            For mosfet checking ,better way is resistance mode with meter set to 200K or higher scale.
              Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
              This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-07-2024, 05:00 AM
              Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
              Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
              This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
